In the weeds or in the woods
Well I need a little help deciding. I own a 1988 R20 suburban silverado and at first I wanted to drag the wagon but after months of cruising the web I'm not so sure anymore. I have built plenty of lowriders be it static, hydros, or bags. Maybe its time to go the other way with this one. I have never built a 4x4. Hell at the moment I have a bagged mini in the garage that I'm trying to get back together after a "so called" shop destroyed it. Its not mine I'm just fixing everything for a friend. I know plenty of guys with bags that I can get my feel for dragging with. Over the last month I've met a few people with 4x4 that have got me thinking
So half ton it and put it in the weeds Or slip a new frame under it and put it in the woods Posted via Mobile Device Posted via Mobile Device
2005 Crew Cab Z71. Family mobile 1999 Grand Cherokee. Daily beater 1988 Silverado Suburban 3/4 ton. Toy 1981 Cheyenne C10. parts truck 2002 IS300 weekend toy. Wife's ride |
Re: In the weeds or in the woods
Lets see some pics of the burban in question!
Cause I think he means that the frame he has is a 2wd frame on it now and if he wants a 4x4 he would need to get a 4x4 frame.
These trucks are so a dime a dozen and it does not make much sense to convert a 2wd frame to 4x4 unless you just want to do it just to do it.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
#5 | |
The conversion could be fun if he wanted the challenge, but no harder than baggin something either. |
#6 | |
As for buying a new burban all together. I will not find one in this good of shape for cheap. The paint job is being done on trade for me redoing the Mazda b2200 in my garage. All my burb needs now is a passenger side window motor and about three pieces of trim inside and it will be close to perfect Posted via Mobile Device
78K & 79C Jimmys
get it up there
do you have a high hump or low?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Not to sure on the hump question. Is this in reference to the trans tunnel. If so it looks kind of low to me but I'm not sure
Could a small body lift take care of the tunnel being to low or should I just use the donor burbs tunnel Lift size I am leaning toward 8" on 38" tires. How I achieve this lift will depend on if I body lift it or not and also it may not be 8 inches all the way around. For example; 6" front springs with zero rates and 8" springs in back. I really don't like the rear being lower than the front be it lifted or slammed Posted via Mobile Device Posted via Mobile Device
#9 | |
id say 4x4,jack it up!
1990 k5 blazer 1990 gmc jimmy 1949 1300 p/u-sold 1977 bbc skylark 96 roadmaster 06 9c1 impala |
![]() ![]() Yes it is a 2wd and from all the research I've done it will be half the work to do the frame swap. I may have found a half ton 4x4 burb to start the build. Just need to find a d60 to go with the 14ff under mine It looks rough in the pics but it's in the middle of being repainted Posted via Mobile Device Posted via Mobile Device
I wonder if the engine cross member would need to be modified to run coils or if simply getting the control arm out of the way would be enough.
Here is a good start as what "not to do". It's a really old link but if you are a bit bored it's funny to look at. Pages of info on various peoples horrid ideas!!
http://www.google.com/url?sa=t&sourc...083Dbtd1Ck2zRg |
#14 | |
#15 |
78K & 79C Jimmys
great link lmfao
#16 |
Well I've been digging all afternoon for a boxy burb on coils and found a good one that was supossed to be use for a tow rig.
Xtreme 4x4's project subUrban gorilla is on coils in the front ![]() Now i just need to get some pics and find some videos of it to get a good idea to start with
#17 | |
big old burb in primer.lot of work to do. |
#18 |
Using a 2WD body on a 4x4 you will have to use a body lift or cut your tunnel out and bolt/weld in a 4x4 tunnel. Unless you do some custom work on the cross members to drop them a bit.
#19 |
i have a lifted 88 burb, in my opinon being a 2wd, DROP iT they look sweet but if you want a 4x4 sell it and get one.
#20 |
x2.a burb as a 4x4 would just be for looks,kinda heavy for of road and just try to turn it somewhere.
#21 | |
http://www.4x4offroads.com/1990-chev...burban-46.html |
#22 | |
78K & 79C Jimmys
#23 |
well it depends if youve decided 4x4 quickest bet would be get different burb thats 4x4 but doing conversion in my opinion is better bet because you can do what you want as you go along and itsjust fun to have project like that
'83 chevy c-10 scottsdale 400 cid 2wd "chelsea" |
#24 |
lift it! i have a 89 half ton burb with 6" springs up front with 5" block and 2" add a leaf in the rear and it levels out perfect with a 3" body lift and clears 38.5" tsl super swampers.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
#25 |
Arrived on a Pale Horse
I've owned my share of lifted trucks. The older I get, the more I can't stand working on the big ones. I'd put it in the weeds...
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
