Old 11-17-2010, 01:41 AM   #1
amullis
amullis's Avatar
Front Crossmember Question!
Well Here it goes. I hope that I did not waste my money but I bought a new front cross-member for my 68 chevy pickup. I think that the cross-member that i bought is for a later model pickup "73-87". I was under the impression that I could unbolt my entire 68 cross-member and simply bolt the later model cross-member in my truck. That was until I got mine out tonight and did a few precautionary measurements and found that my 68 cross-member is about a half inch wider at the point where it bolts to the frame. I hope that I did not waste my money on this newer model (already rebuilt) cross-member!!!
If you guys have any suggestions as to how I can fix this problem I would greatly appreciate them.
Thanks,
AMullis
amullis is offline   Reply With Quote
Old 11-17-2010, 01:58 AM   #2
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Front Crossmember Question!
have you searched this on the board? I opted to stick with my factory one just because it was easier for me, but I do remember reading it wasn't a direct bolt in and there was some drilling to do, any pics of the issue?
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 11-17-2010, 02:13 AM   #3
jayman68
Fun Stuff
jayman68's Avatar
I did the swap in my '68. I put the crossmember out of a '78 into it. The member slid right under and bolted up from the bottom directly. I then had to drill thru the sides, but it was a pretty good fit. I can try to get some pictures if you would like.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 11-17-2010, 08:15 AM   #4
amullis
amullis's Avatar
Thanks for the info!
I will attempt to take some pics of progress tonight and post them up.
Old 11-17-2010, 08:40 AM   #5
dyrt
If you can post up a picture of the new crossmember. Without modification you can actually bolt it in to fit it so you can mark the two holes that you need to drill and the two you need to file out. Keep in mind that these frames are kind of flimsy, we're not talking hydroformed rails, so chances are that when you bolt it in it will snug up just nicely. I actually freed the upper arm towers from a later crossmember and used them with my original 69 main section since it was in better shape. Still had to drill the holes, worked great.
Mike
dyrt is offline   Reply With Quote
Old 11-17-2010, 10:47 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I posted some info and pics in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=272538
LockDoc
Leon
Old 11-17-2010, 08:33 PM   #7
gkesseru
gkesseru's Avatar
I put an 81 front end in my 68. The 68 frame measured 1/4 wider than the 81 frame. I got the crossmember to fit by slowly driving it back with a large hammer. I used some tapered rods to line it all up at the end. I think yours should line up the same way. One item no one mentions is that the engine mount towers will need to be modified. See my build thread for how I fixed this.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 11-17-2010, 10:35 PM   #8
amullis
amullis's Avatar
Got home a little early tonight and was able to snap these shots. Let me know what you guys think.
Old 11-17-2010, 10:40 PM   #9
amullis
amullis's Avatar
Here are a few more of the rear 6" drop, the new ECE dropped spindles and the old girl as she sat tonight.
Old 11-17-2010, 11:58 PM   #10
LockDoc
LockDoc's Avatar
I don't see a problem with that... The later frames usually have an angled stiffener inside the frame rails that I save and install with the swap.
LockDoc
Leon
