11-18-2010, 11:33 PM | #1 |
5.3 engine mounts
I have a 1960 apache and I am swaping in a 5.3 I have looked at the threads of the different motor mounts but I am unsure which one to use. anybody have any suggestions or comments on which ones I need to get?
11-19-2010, 01:14 PM | #2 |
Re: 5.3 engine mounts
This is what I used...
http://www.performanceonline.com/196...LT-IN-ECM6372/ There are also some mounts from ECE that are cool. more $ tho http://www.earlyclassic.com/catalog.aspx good luck, you will love the 5.3
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-20-2010, 08:03 PM | #3 |
I already have a 350 in the truck so are those what I will need I was thinking that I only need the bracket for the engine.
11-20-2010, 10:50 PM | #4 |
depending on your exhaust manifold/header clearance, what you have for engine stands may work.
I made my own adapter plates to be able to bolt my 5.3L to the SBC motor mounts. There are a few threads about how to do this. Might check the lsx swap info sticky thread above.
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 11-20-2010 at 11:17 PM. |
