11-19-2010, 06:54 AM | #1 |
what is stock tire diameter?
just curious how much (if at all) my speedometer is off with 31/10.5r15
Thanks, David |
11-19-2010, 07:41 AM | #2 |
Re: what is stock tire diameter?
If you have someone with a gps you could borrow it and read what actual speed was vs. speedometer readout at commonly used speeds i.e. 30mph, 45mph, 60mph. Most gps units have a mph function. You are probably 3-4" higher than stock original tire (depending on truck) so it would be my guess you will be off a ways. For example, if the original tire was 28" tall and you are running 31" tires, your tire is 10.7% larger in diameter.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
