Old 11-21-2010, 10:10 AM   #1
moovinmetal
moovinmetal's Avatar
1965 GMC engine swap 305v6 to350sb
not sure if this will work but, here it goes. will the 350 v8 mate to the bell housing of the GMC stock3 speed and will the 350/3 speed with HEI sit at right height on the stock bell housing cross member and with this combo will the frame mounted crossmember engine mounts work. Thank you, Jack
moovinmetal is offline   Reply With Quote
Old 11-21-2010, 11:57 AM   #2
oldtrux
oldtrux's Avatar
Re: 1965 GMC engine swap 305v6 to350sb
does a 350 block have the threaded holes on the drivers side for the mechanical clutch linkage?dan
oldtrux is offline   Reply With Quote
Old 11-21-2010, 12:31 PM   #3
duallyjams
duallyjams's Avatar
305 v6 bell housing will not work on a 350 smblk
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-21-2010, 07:21 PM   #4
mikie 1954
YOU will need a differant bellhouseing, one from a chevy v8 pu up to I believe a 68 after that they had a larger center hole.I think some i6 bells would work to but not sure of this. The motor mounts are also differant.AS for the driverside threaded hole , some do some don't you will have to look and see.
mikie 1954 is offline   Reply With Quote
Old 11-22-2010, 02:09 AM   #5
Captainfab
60-66 Nut
As long as you use the Chevy V8/I6 bellhousing and the '63-'66 motor mount brackets, you should be fine. And of course as mentioned your 350 will need the threaded boss for the clutch bellcrank ballstud. You will also need to use exhaust manifolds or headers that will accomodate the clutch bellcrank.
Old 11-23-2010, 07:53 PM   #6
raycow
The bellhousing center hole changed in 68, so you want one from a 63-67 truck. 6 cylinder and V-8 are the same. If you can't find one, you can use a 68-72 bell, but you will need a spacer ring to take up the difference in diameter.
http://dennymac.com/mod.php?mod=user...103&page_id=54
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-23-2010, 09:13 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
One thing you will notice as well; the stock GMC bellhousing is where the rear mounts are located. There are no tranny mounts, only on the bell housing so if you swap bellhousings, you will need to get a tranny bracket for the tail cone.
Old 11-24-2010, 06:58 AM   #8
raycow
All of the Chevy truck bellhousings through 72 have the mounts that sit on the crossmember just like your GMC bellhousing. As long as you use one of those, you will not have to do anything about an additional mount or crossmember for the transmission.
Ray
Old 01-11-2011, 01:30 AM   #9
codyshawn1974
i just finished this swap myself in a 1963 gmc. had to use engine perches from 1965 chevy, got the bell housing from 1970 3/4 chevy used original clutch stuff. currently swapping out the sm420 and going in with sm465. having to shorten driveshaft 3 1/2 inches in the front section to fit. 3.08 gears are next in line for the beast. even rewired it for later style alternator and hei distribuor without cutting a single wire.
codyshawn1974 is offline   Reply With Quote
Old 01-11-2011, 02:19 PM   #10
1adam12
1adam12's Avatar
Could you put in a 350 behind the Sm318 tranny? I have 305v6 thinking bout changing it...So i need a motor with holes on side for linkage also i can use all the linkage....
1adam12 is offline   Reply With Quote
Old 01-12-2011, 12:57 PM   #11
codyshawn1974
Thumbs up Re: 1965 GMC engine swap 305v6 to350sb
i believe your asking if a 350 engine will work with your setup as far as the tranny goes. i think it will. i didn't have any problems with the tranny matching up. as long as you use the clutch assembly that goes with the tranny your using and have a 350 bellhousing with the mounts on it. there is a differance between the car bellhousing and the truck bellhousing. cars have no provision for mounts. truck ones do. and don't try to use the perches from a 67-72 chevy. don't work, sits the engine too high. the clutch z bar is different also. get the one for a v8 truck. it makes a difference. that's all i can think of at the moment. good luck!
Old 03-08-2011, 11:32 AM   #12
codyshawn1974
I discovered something new on this swap. the clutch linkage has problems lining up with everything else with the stock units from the 305 v6. the v8 sbc version has the clutch linkage on a different mounting point on the frame rail. i had to use an angle grinder with a 3" cutoff wheel to cut off the rivits holding the bracket in place. my setup came off of a 1966 chevy duelly 327 sm420 (4 speed). i simply bolted the new bracket into place on my frame rail in the stock position of the 327, which is a little bit further forward on the rail. there is another hole already drilled in mine and was very easy to relocate the clutch linkage. now i have no binding, no clatter or loose feeling either. it did make a difference inside the bellhousing as well. the clutch engages with a better feel than before.
