11-21-2010, 12:34 PM | #1 |
S10 swappers - inner fender pics please
I'd like to see final or at least close to final cuts on the inner fenders from a front shot without the grill. The other shot that wold be helpful would be an engine bay shot without the engine, just inner fenders bolted up and positioned properly. Thanks!
Posted via Mobile Device |
11-21-2010, 08:12 PM | #2 |
Re: S10 swappers - inner fender pics please
Vintage I'll try to help you out, I just did this, it will be tomorrow. I just got my front radiator support built and have my inner fenders in, but I am far from done and sorry I'm not pulling my engine for that shot. I did look through a lot of peoples build picture and got an idea of how I wanted it.
11-21-2010, 09:53 PM | #3 |
come on rootbeer...pull the engine like I asked, it's just 2 bolts! Are you using the stock radiator or aluminum radiator?
11-22-2010, 10:58 AM | #4 |
We had to make all of that stuff
1955 First Series Thriftmaster Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s, |
11-22-2010, 11:01 AM | #5 |
I need a tissue... MY LORD!
11-22-2010, 01:45 PM | #6 |
For us less talented folk using free child labor this is what we did, We followed the opening for the original steering box and cut along the first line in the panel, we did the right side first and it didn't turn out as well, divers side turned out pretty good.
11-22-2010, 01:47 PM | #7 | |
11-22-2010, 09:28 PM | #8 | |
Here's my core support and 19x22 radiator. and I'm happy with my gaps:
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
11-22-2010, 01:48 PM | #9 |
Texas I drooled over yours but I'm not talented enough to build them but like any good teacher I accept donations.
11-22-2010, 01:50 PM | #10 | |
We dont have the tools to really do alot of sheetmetal custom stuff but we finally got it close after a couple of sets lol. Thanks for the compliments.
11-22-2010, 02:15 PM | #11 |
thanks for the pics rootbeer...perfect guideline for me. Texas, if you hate yours I will gladly pay the shipping for you to send the set to me. Looks really good.
11-22-2010, 03:29 PM | #12 |
Finally find a pic that might help.
11-22-2010, 03:51 PM | #13 |
rooster, are you using the stock radiator, or going with an aftermarket. Does the supports on the grill clear your frame rails? On my test fit the bump against it. I would move the cab forward, but it is centered on the wheels. I would cut more of the front frame rail, but it is cut right were others have cut theirs. Didn't know if welding some flat stock was required and just cutting the orignal supports off was necessary.
11-22-2010, 05:35 PM | #14 | |
11-22-2010, 04:51 PM | #15 |
Vintage
this is the stock radiator and how much to the bottom, 19" is the norm and were it will fit,running a electric fan I will have plenty of room. I will have to run an aftermarket, jegs and summit have them 156 or so. one more thing to keep in mind mine is setting a little higher so if your is lower you might need to do more trimming. Last edited by RootBeer 6117; 11-22-2010 at 04:55 PM. |
11-22-2010, 05:08 PM | #16 |
would the stock radiator and electric fan provide enough cooling for a 350 v8or should I just go to jegs and give them more of my hard earned money for aluminum one?
11-22-2010, 05:32 PM | #17 |
AD Addict
We are using a stock radiator on our 327 .060" over with a stock V8 fan. I tilted the bottom of the radiator out to clear the S10 steering box. No overheating issues thus far. I had a radiator shop open the top outlet pipe up a size.
11-22-2010, 05:34 PM | #18 |
Not sure if you could get a stock one to fit unless you leaned if forward at the bottom.I figure 150 to keep from burning up an engine is good insurance, We have a radiator shop in town that might be able to build one for me but I doubt it would be cheaper than $150.
I guess 150 doesn't seem like much to me cause I had to spend $300 for my wifes Tahoe a few years ago.I understand using as many old parts as possible cause I ain't got a whole lot to spend, If I hadn't found this site I would not be doing my build this saved me a bunch. |
11-22-2010, 05:44 PM | #19 |
I learned a lot from this build
http://www.killbillet.com/showthread.php?t=16296 |
11-22-2010, 11:47 PM | #20 |
Those pics are great! I'm just getting started on my '50, trying to figure out where to mount my cab. All these inner fender shots & comments are helping out a lot. thanx!
11-23-2010, 07:18 PM | #21 |
I have to second (or third) what Texas and Blue jeep said it took me 2-3 week to get the front end done I was beginning to wonder if is was going to get done it wasn't easy. I am very glad guys like Blue Jeep and Jeff's 51(I think he was the one that posted the frame mounts) posted their builds it has been a big help. I want to help the fellow builders as much as possible.
