Truck and auto performance nut
3* down angle on Power booster/Master cylinder?
Does this look normal...or did I somehow get the wrong bracket or something?
New CPP power booster/MC/prop valve combo...mounts up with 4* down angle (title is wrong)....which 1* is coming from the truck...other 3* from the bracket. I'm used to seeing these setups lower in the back... then in the front. ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 11-21-2010 at 06:23 PM. |
Re: 3* down angle on Power booster/Master cylinder?
Does the booster line up with the pushrod hole in the firewall? If not, could you have the bracket inverted?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
this came as a complete assembly from CPP just as shown. The bracket has 5 holes....the 4 main plus it uses 1 of the steering column bolts....no way it could be upside down.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
vw guy & now c-10 guy
![]() Join Date: Sep 2008
yeah, that looks weird. I have that same set-up on my truck and im pretty sure it's mounted straight up and down- no lean...
Did you ask CCP about it? It does look a little off, it still looks great- but off a little. I got my bracket from a Fiero, its shorter than the stock ones but its level.... Things that make you go "HUM
if you look at the bracket where it meets the booster....the top is out further then the bottom. Most brackets I've seen where the other way around...tho this one cannot be inverted.
Sent Jeff a PM with the pic...we'll see what he comes back with.
Redefining LowBudget
mine is a stock one and it looks the same way I have scatched my head over it a million times too??? but it works fine and since its the oly way it will bolt to the stock bolts I figured it was just onew of those dumb things
might be a pic in my build
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Yes that is normal. Mine is the same, stock. It has to do with the linkage behind it.
60-66 Nut
I agree. That is a stock '67-'72 booster assembly. They obviously work fine, but I just don't like the look, or the distance out from the firewall. That is why I make the booster brackets that I sell.
you have a different bracket? I understand the reason for the booster position is to clear the hood? Do you have any pics of this bracket? ....or even installed?
Thanks edit---found in your sig....but understand I'd have to also buy a new booster? and m/c or no?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 11-28-2010 at 03:10 PM. |
