11-23-2010, 02:54 PM | #1 |
front end swap from 70 to 68 how hard is it?????
me and my dad like the 67 n 68 front alot more than the 69 72 nad my dad would like to chandge his truck from 70 to 68 we found a guy who has a front end from a 68 50th annv. and we would like to change front ends in one or two days waht needs to happen
11-23-2010, 02:58 PM | #2 |
Old Skool Club
Re: front end swap from 70 to 68 how hard is it?????
If you have the "want to", that's 75% of the job.
Look at www.lmctruck.com website and find their catalog for these trucks. You should find their line drawings for the sheet metal and be able to see where the bolts and cushions are. There are bolts that hold the inner fender to the outer fenders. There are bolts that hold the outer fenders to the cab. There are bolts and cushions that mount the radiator support to the chassis. For the swap, you need the fenders (in/out), hood, grille, radiator support.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
11-23-2010, 03:42 PM | #3 |
i know but what i meant was avout thewiring and technical stuff i have taken off front ends and put them back on a bunch of times but not one so trucks that are running workind order
11-23-2010, 03:58 PM | #4 |
Master Procrastinator
as far as I know the wiring is interchangeable just don't have the marker lights on the 67's, other than that it's different hood, grille, fenders, and rad support, 68-72 gmc's also are the same as the 68 chevy fenders
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
11-23-2010, 05:46 PM | #5 |
Has more rust than truck...
Swap the entire clip whole, keep your existing rad. support cushions and wiring. There is a how to on removing the clip in 1 pc.
11-24-2010, 11:41 PM | #6 |
Still Just Havin Some Fun!
can someone explain this to me? So my 72 GMC fenders are the same as the 68 Chevy fenders?
a green one with some stuff done to it.... |
11-25-2010, 02:00 AM | #7 |
Big Red - Now its a SWB!
That is correct.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
11-25-2010, 03:00 AM | #8 |
see gmc guy are lucky when they want to shave the side marker lights on ther 72 gm all they have to do is get 67 chevy or gmc front fenders and its shaved chevy guys got the worst part of it thats probably one reason why i am having a hard time trying to find a passenger fender for my 67
11-25-2010, 11:46 AM | #9 |
the mounts on the frame for the radiator supports are different. the 67-68 bushings are smaller diameter than the 69-72. i have never done this swap so, i have no idea if you can use the 69-72 bushings on the 68 radiator support. i just know for sure the frame mounts are different.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed Last edited by redbaron69; 11-25-2010 at 11:46 AM. Reason: spelling? |
11-23-2010, 10:18 PM | #10 |
Bolt and go
11-24-2010, 09:45 PM | #11 |
Who's got steelies?
Easy. Taking the front bumper off is probably the hardest part if it hasn't ever been off. (core support bolts second)
You can do it by yourself with a cherry picker, or have friend help you take it off and put it on.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-30-2010, 12:02 PM | #12 |
So if I wanted to put a 68 hood/grill on my 72 GMC I would need what? Hood, grill, rad support and?
11-30-2010, 12:19 PM | #13 |
Fenders
66 el Camino 70 1/2 RS Z-28 71 C10 2wd 72 2 wd Blazer (2) 72 4 x 4 Blazers 88 24' Mirage 70 mph+ 08 Harley Night Train 08 Silverado 4d 4 x 4 |
