Old 11-24-2010, 08:52 PM   #1
60apache
60apache's Avatar
pcm location
getting everything ready for my ls1 swap. motor mounts came in today. now I am trying to get my wiring harness. I would like to see where you guys put your pcm. pics would be nice. also has anyone put theirs under the seat? This would seem like the most out of the way place. if so what harness did you use.
60apache is offline   Reply With Quote
Old 11-25-2010, 01:02 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: pcm location
I'm planning on mounting mine in the cab under the dash.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 11-25-2010, 06:49 AM   #3
67C10BUB
67C10BUB's Avatar
Re: pcm location
I mounted mine in the factory location (driver front) using the factory mount. See my thread for more info.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 11-28-2010, 08:15 PM   #4
60apache
60apache's Avatar
Re: pcm location
what is the factory mount off of?
Old 11-28-2010, 09:20 PM   #5
67C10BUB
67C10BUB's Avatar
Re: pcm location
The 2008 Silverado that the motor/trans are out of.
67 5.3L Build
Old 11-27-2010, 10:14 AM   #6
BustedTruck
BustedTruck's Avatar
Re: pcm location
I put mine under the seat along with the TAC module & fuse block. I wanted it all hidden for a cleaner look. I like it there so far, but I haven't put many miles on it yet.
BustedTruck is offline   Reply With Quote
Old 11-27-2010, 03:21 PM   #7
tonypaul
tonypaul's Avatar
Re: pcm location
Mines a Vortec 454 and not a Lsx but I put my pcm under the dash. If you buying a aftermarket harness make sure to have them add 2 or 3 more feet to the harness if your going to mount it under the seat. Theres no way my harness would have reached....
tonypaul is offline   Reply With Quote
Old 11-28-2010, 12:38 AM   #8
TR65
TR65's Avatar
Re: pcm location
I put mine on the inner fender and used the stock harness. (LS2 E40 PCM)
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
