11-27-2010, 01:56 PM | #1 |
HillBilly 53 build
I have been watching everybody elses builds on here and thought I would finally post some pics from mine. I drove to alabama to pick up this 53 for $800 from a friend. I have put a mustang II under the front and have started on the rear suspension. Drivetrain will be a ~450Hp 350 with a T56 6 speed and a 8.8 rearend from a f*** Exploder.
11-27-2010, 02:19 PM | #2 |
Re: HillBilly 53 build
Wow man, looks like a great start...with exception of that flat tire
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
11-28-2010, 01:12 AM | #3 |
looks good
11-28-2010, 11:12 AM | #4 |
Thanks guys, Yeah that flat tire made for a good push to get it in the garage. The rearend that was under it, connected to that flat tire, was a 12 bolt out of a 79 chevy 2wd. So it was too wide and had to come out anyway.
11-28-2010, 12:29 PM | #5 |
Heres somemore pics of the way it looked when I unloaded it off the trailer from its long trip from Alabama to its new home in Wv.
11-28-2010, 12:39 PM | #6 |
looks good...looks like you got a good deal @ $800.00 bucks. keep the pics coming.
11-28-2010, 01:01 PM | #7 |
Heres a pic of a buddys 49 wearing its original paint.
11-28-2010, 09:57 PM | #8 |
Another friends truck, hes running a caddy front sub frame and a 455 big block.
02-20-2011, 11:29 PM | #9 |
Thought I would finally show a little progress. I have C-notched the frame using a peice of 4" pipe and have finally settled on the setup for the rear suspension. I still havent welded up brackets for bags or shocks but will throw some pics up of that when I get it done.
02-20-2011, 11:41 PM | #10 |
02-20-2011, 11:45 PM | #11 |
02-21-2011, 01:20 PM | #12 |
Nice build. Where is the front end from?
02-21-2011, 02:04 PM | #13 |
Tci
Posted via Mobile Device |
02-21-2011, 02:19 PM | #14 |
Tci
02-24-2011, 03:03 PM | #15 |
lookin good hillbilly. are you planning on putting your fuel tank in the rear frame section behind your axle? the reason im asking is i read on here i cant remeber what thread it was but the guy had done all the math to figure this out, he said when you c-notch the frame like you did you lose like 60 to 75% of the strength in the frame behind the notch. i wish i could remember what thread it was cause i seen alot of guys do the notch like that. anyways just thought i would throw that in. Charleston Vw. Hey i got kin that live in barberville and my mom was born in charlseton. know any Tocks or McCoys ??
02-24-2011, 03:15 PM | #16 | |
I'm 225 lbs and can stand on that tank with zero flex on the frame. It flexed like a SOB before the shock tower was welded in though. |
02-25-2011, 12:04 AM | #17 |
Ya Ghost i totally agree. when the guy explained it he even showed diagrams of braceing it. i believe the way you welded that plate your crossbars are welded to strengthen yours up alot. dang i wish i could remember that thread it was in. like i said i seen a ton of people do c-notchs that way. i think with braceing it would work great.
02-25-2011, 05:15 PM | #18 |
Troy, I have heard of a couple McCoys but none ring a bell. I do plan on putting a tank back there, But I am also going to build a frame out of 2"x2" for what I am doing for the bed floor, which will also give it a little backbone. Really with the 3/16th stiffners I welded in the center of the frame before I boxed it, I wouldnt worry about it. I can put a lot of weight on it, even supported at the rear of the frame and it doesnt flex.
Thanks I am going to try to build my motor mounts this weekend and put them in, but I may run over to my buddys to help get him started on his 46 chevy truck. |
05-13-2012, 09:16 PM | #19 |
Thought I would post some progress.
05-13-2012, 09:38 PM | #20 |
Motor mounts.
05-13-2012, 10:09 PM | #21 |
Some more, even had the ol lady welding on the box plates.
05-13-2012, 10:12 PM | #22 |
Some more....
