What gears should I run?
I figured I'd post this here since my plans are to have a 6.0. I am either going to have a 4l80e or 4l90e depeding on whether I buy an engine I'm looking at or not. I'm not sure there would be a difference since they are both 4 speeds. I have the same rear wheel set up that Dennis has on silver's build which I'm assuming everyone looking at this has seen. I have a 12 bolt that I am re-doing and basically changing everything. 3.73 gears seem to be popular on this kind of engine swap so I was thinking about going with them. This isn't my every day drive but hopefully it will be someday. Thanks for any information anyone can provide.
Jordan 1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205 1982 Chevy C10 SWB, 2006 LS2/4l70e In progress.... http://67-72chevytrucks.com/vboard/s...d.php?t=439860 |
One day...
Re: What gears should I run?
3:73 is a good all around gear and its good for playing around and towing, I put them in my DD and love them.
Has more rust than truck...
Here is a spread sheet for gear ratios. Just experiemnt with different rear ratios until you get what you want. I'm going 3.73.
http://67-72chevytrucks.com/vboard/s...d.php?t=274314 |
Big Red - Now its a SWB!
My 01 tahoe has 5.3, 4l60e, and 3.73's it is heavier than your truck and has 32"x12.5" tires and it is a good all around gear. I've towed a 6000 lb. trailer with no problems before. When cruising down the highway at 70 MPH I'm spinning right at 2000 RPM.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
