God is good!
Battery Ground Location
I am routing my underhood wires to make for a cleaner appearance. I have the battery ground cable that grounds to the alternator bracket (passenger side).
It would look much cleaner out of sight. There is an empty bolt hole under the fuel pump rod bolt hole. Would there be anything wrong/risky in grounding it there? I don't think so but I've never done this. Thanks.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
Re: Battery Ground Location
I am really not an expert here...but I think you should be able to ground your battery there....I'm pretty sure you can ground your battery just about anywhere right? Like the chassis?
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 Last edited by THE "10" SILVERADO; 11-28-2010 at 11:07 PM. |
At the body shop.
put a star washer for a good ground. i use the front of the head.
" That didnt make it any newer " " Dont antique the equipment " |
#4 | |
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
![]() Join Date: Dec 2008
Sweet fix...
2011 silverado 2500hd ext. cab 6.0 2007 tahoe lt 2004 harley-davidson superglide 1982 chevrolet c10 stepside 2 wheeldrive..current project |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
So, whats up with the water pump gasket? lol, i'm curious!
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Oops I read something wrong so there isn't a point to this post
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 Last edited by THE "10" SILVERADO; 11-28-2010 at 11:44 PM. |
At the body shop.
Lol a trashcan fix for a blown out gasket. Been there for two years. Milk duds to be exact
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 11-28-2010 at 11:43 PM. |
6.0 powered square
I have my battery mounted in the bed, I have the large cable bolted to frame and I have the smaller wire grounded to the bed floor, then I have a ground strap from the block to the frame, block to body, and body to frame
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-29-2010 at 12:12 AM. |
just make sure your small ground straps go from the block to the frame and frame to the body... then you can ground anywhere you like. I would do block or frame.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Another Day, Another Dollar
hang on, your trying to clean your truck up under the hood, but you have a milk duds package for a waterpump gasket.
lol
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
6.0 powered square
KQQL IT was showing his ground cable location not the road side repair
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
At the body shop.
dont laugh too much its lasted longer that the fel-pro gasket
#15 |
#16 |
God is good!
Thanks a lot, guys. I appreciate the input.
#17 |
no harm intended, it was just a funny observation
#18 |
At the body shop.
None taken at all
i hadnt seen the pic in two years got a LMAO...
#19 |
yes you can run ground strap there . just make sure it is clean and you can run another from there to the frame. as far as body off back of block to the firewall.if you can find the flat strap braids that is what came on most. and when clean look nice. and yes use star wasers.
1970 CHEVY MONTE CARLO NHRA/IHRA STOCKER 1976 PONTIAC GRAND PRIX ORIGINAL EXCEPT INTAKE AND CARB 1979 3/4 TON CAMPER SPEICIAL PROJECT |
#20 |
![]() Join Date: Sep 2012
2013.....Im curious if the milkdud box is still hanging tough?
#21 |
![]() Join Date: Jul 2010
This...lol
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#22 |
I've made thermostat gaskets from brown office folders many of times. But never from a candy box out of the trash. Sweet, Redneck Engineering. Gotta love it.
#23 |
#16876
^Lots to chew on there.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#24 | |
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#25 |
At the body shop.
Lolol still there since. The edges have weathered but still going.
Posted via Mobile Device ![]()
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-09-2013 at 05:47 PM. |
