Old 12-01-2010, 02:18 PM   #1
jmanthony65
jmanthony65's Avatar
73 K5 to 3/4 swap???
I bought a 73 K5 with 35s but it still has the 3.07 gears needless to say it doesn't exactly get up and go.. I was thinking I probably could pick up a used set of 3/4 ton axles with 4.10s already for around the same money as swapping in gear sets. I was wondering what year models if any will pretty much drop right in or what complications or issus I will need to look out/prepare for? I welcome any opinions and help...
jmanthony65 is offline   Reply With Quote
Old 12-01-2010, 11:31 PM   #2
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: 73 K5 to 3/4 swap???
If I'm not mistaken, this will be a direct bolt-in if you get the pair of axles from the same donor truck. I swapped in a 14 bolt ff rear from a '79 3/4 ton truck to a '79 K5 and it was a direct bolt in. Did it all in a few hours. To be sure, just take a measurement from spring perch to spring perch. I did have to get different U-bolts (the axle tubes on the 14 bolt are larger) and you are going to have to get another U-joint for the shaft. I forgot what the part number was but it is readily available at the parts stores. I didn't swap in the front axle assembly because I found out it was shot when I opened it up.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-02-2010, 02:34 AM   #3
Altec
Getcha Pull
Altec's Avatar
The spring width is the same on 3/4 ton, it is 1 ton that is different.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
