3 on the tree - trouble shifting
As the winter weather gets here
it becomes harder and harder to get my truck into 1st or Reverse. Pulling back from 2nd and 3rd is impossible when it's cold enough (50degress or so). Probably wont even be albe to drive it to work in the am tomorrow. If I'm able to get it into gear, and get to work, once I come out for lunch and the weather has warmed up it seems to work fine. Totallly dependent upon the temp outside Oddly, running the truck until it heats up to running temp does nothing if its cold as hell outside.... What can cause this...? |
Re: 3 on the tree - trouble shifting
The grease in the column shift mechanism could be getting too stiff because of the low temperature. Try washing it out with solvent and re-lubing with something thinner.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
Ok, I'll check it out.
Will this require a wheel puller? Never taken the steering wheel off this truck.. Thanks guys! |
Yes, you will need to get the turn signal switch out of the way so you can get to the shift mechanism.
Ray
BLACK SATIN
![]() Join Date: Jan 2009
I have taken the shift lever off & sprayed WD40 or equivalent in there & helped mine out alot.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci |
Great.
I'll give it a try Saturday. Thanks for the advice y'all! |
I pulled it all apart,
and now cannot get it back together properly. I assembled the turn signal mechanism but I'm not sure what to do from there... When I place it over the column it doesn't seem like it sits right... and when I put the wheel into place the column threads don't stick out past the surface of the wheel What am I doing wrong? Is there a diagram somewhere that I can reference? |
