Old 12-01-2010, 09:15 PM   #1
austinstocker
austinstocker's Avatar
Cab Questions: Non-A/C v. A/C
I have an A/C cab that is in amazing condition, and want to swap it on to my NON A/C truck. Since I do not have the heater box ect. off of my truck right now, my main question is: How similar are the cut-outs in the two cabs? Can I simply patch off some holes from the A/C cab and bolt up a Non A/C box to it?
Any info would be appreciated.
As far as the vents in the A/C cab, I will probably patch them or utilize them rather than cut the complete dash board out.
Thanks.
____________________________
1967 C10 SWB Big Block 4 Speed
austinstocker is offline   Reply With Quote
Old 12-01-2010, 09:32 PM   #2
JimKshortstep4x4
Re: Cab Questions: Non-A/C v. A/C
Here is a picture that a member made up sometime ago that shows the differences in the firewall.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-01-2010, 09:42 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Are you intending to have factory AC? Do you have the "stuff" you need to create the system?
My situation is this: My '69 air cab is toast, as far as the firewall is concerned...and it is serious. The rest is okay. So, I was able to pick up a nice '68 non-air cab. I don't want to have factory air because it takes up so much space under the hood.
So, what's your plan?
Member Nr. 2770
Old 12-01-2010, 09:46 PM   #4
austinstocker
I am planning on leaving my truck as a Non-A/C truck.... I don't think I would want the mess of an A/C system and a big block under the hood. I like to keep it simple..
Old 12-01-2010, 09:49 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I misread your intention. You want to keep a non-air cab, so I see what you mean. The vents on the air cab, in my opinion, would work for sending some warmed air you direction, if you can create the distribution plenum to route it. Otherwise, some patch pieces could be cut from the non-air cab dash to fill in the holes.
Member Nr. 2770
Old 12-01-2010, 09:40 PM   #6
austinstocker
Jim, Thanks for the information. Looks like I will have to spend a little more time with it.
Old 12-01-2010, 09:52 PM   #7
austinstocker
Yeah, those are both good ideas. I was thinking about making them vents as well, but they would be relatively close to the kick panel vents... so probably a lot of work for not much effect.
Old 12-03-2010, 03:32 PM   #8
Dano69c10
Dano69c10's Avatar
You could go this route.
"Non-A/C units for A/C cabs."
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 12-06-2010, 09:23 PM   #9
austinstocker
Thanks for the info Dano. Looks like a pretty clean box compared to an original too.
