03-05-2003, 08:31 PM | #1 |
Radiator swap info
I am changing from a 3 core to four core radiator. I am sure the radiator supports have to change, upper and lower.
I am changing to electric fans so the cowling is out anyway. Does anything else have to change? Thanks Mike
"Success is going from failure to failure without losing your enthusiasm" (Abraham Lincoln) |
03-05-2003, 08:39 PM | #2 |
BAD BOW-Silverado XST
The three core radiator use two brackets to mount at the top. The four core radiator uses only one large bracket. You will need four new rubber pieces to fit the new radiator. Two for the bottom and two for the large bracket on top. The top bracket covers the entire top portion of the radiator. Here is a picture of the bracket.
For complete details on the parts I used go here. Read this post in the engine forum. |
