Old 12-04-2010, 09:00 PM   #1
2003 silverado
2003 silverado's Avatar
Question Radiator Core support 3row/4row
Ok started working on the blazer.Found frt brake line was shot,went to replace and found removing inner fenders made this task easy.Well then the SNOW BALL went into effect. I bought a rad support ON line and when i got it it was a 3row I need a 4row.according to LMC in there catalog i need to make slight mods to make this work. The question i have is do the retainers for 3or4 row just clip in existing holes????the one i bought is tacked in.
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 12-06-2010, 10:58 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Radiator Core support 3row/4row
WHen I swaped mine from 3 to 4 I simply bought the 4core brackets from classicparts and the worked fine with my core support in my 72.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-06-2010, 11:59 AM   #3
2003 silverado
were the 3 row lower supports snapped in or tacked in? and does the 4-row lower retainers bolt in or snapped in
Old 12-07-2010, 10:54 AM   #4
Burt4x4
Burt4x4's Avatar
I'ts been several years...I remeber buying the longer brackets for the top and I can't recal exactly what the lower mounts needed...If I remember too I will look at it tonight and maybe that will jog my brain...
Old 12-07-2010, 11:02 AM   #5
jaros44sr
jaros44sr's Avatar
mine were tacked in, just drill it out, then I bolted the new set in. Used a button head bolt and rounded out the rubber mount for clearance so the rubber mount would sit flat
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
