New yard ornament
Picked this one up for 500 bucks a couple of weeks ago. 93 ecsb 4X4, I hope to swap the motor out before christmas and bring it back to life. Budget revival, hope to have it on the road for under 1000 bucks. Wish me luck!
92 Silverado 93 Silverado 87 Grand National ![]() |
The One And Only !!!
Re: New yard ornament
Dude, What kind of gun did you use ?
I can't get a bed alone around here for 500 bux..... ![]() Best of Luck !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
One day...
Not a bad score at all!!! All it need is an engine?
No gun, just right place at the right time. Got lucky I guess. So the guy said the truck would die when you put the truck in gear. Motor sounds like it's going come apart, got shavings in the oil. I did put it in gear and move it around. So it moves,I got another 350 to put in. It needs a heater core and probably some brake work, other than that who knows. More to come.
92 Silverado 93 Silverado 87 Grand National ![]() Last edited by dcnoel08; 12-06-2010 at 12:45 AM. |
Bad news, both heads are cracked. Good news had another set to take in. Hopefully I'll get them back before christmas break.
Still waiting on my heads for the replacement motor. I did however score a dash from the local salvage yard for 40 bucks, not a single crack in it. I even managed to pull, transport & install it in my truck without breaking anything! I'll get a pic of it in the truck later.
Dash pic, finally!
Got my heads back, should be dropping it in next week sometime.
did you doing anything special to the motor like boar or cam or is it all stock?
IM ONLY 18 AND LOVIN IT IF MUD AINT FLYIN YOU AINT TRYIN! 1badgmc- Just think. Someone worked hard to make it look that bad. 1988 chevy stepside 305 five speed ![]() 1994 GMC ext. cab short box 350 auto ![]() 1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build 1998 GMC K-1500 ECSB 305 auto partd truck 1999 GMC K2500 suburban 350 4x4 Dads project 1981 Corvette 350 auto Also Dads project 1989 Corvette 350 auto ^^ 1998 GMC K1500 ecsb 305 auto Brothers project |
Nothing special, everything is stock. This motor was in a buddy of mines truck up until 2 years ago when he replaced it with a higher performance motor. This was just going to be a simple head gasket, oil pump and a few other minor things and stuff it in to my truck. I was hoping it would all go together good, but while changing the valve guide seals my valves were bypassing. Off to the machine shop with the heads. Anyway got the heads back Friday. Basically I am building this truck to use as a truck, I just want to get it going!
haha sounds nice
