Old 03-06-2003, 01:23 AM   #1
mikep684x4
Seeker of the big and bad
Just trying to pst a pic
If this works this is my $500 truck i drove home last month.
350 motor with a turbo 350 trans,205 transfer case,14 bolt with a factory locker,44 front with a posi,new tires and all the lights and electronics work,I found out even the windshield washer works.The built paper said it was orange and white with the sport crome.Dose this mean it was white in the middle with a white roof or white bottom?
71 3/4 ton 4x4,665hp 454.
67 GMC 1 ton towtruck
68 chevy LB 4x4
64 chevy LB custom
57 Bel-air 2d station wagon
mikep684x4 is offline   Reply With Quote
Old 03-06-2003, 01:41 AM   #2
mikep684x4
one more time
68 chevy LB 4x4
64 chevy LB custom
Old 03-06-2003, 09:34 AM   #3
Blue Beard
Blue Beard's Avatar
mike,
When you Post a New Reply, just below where you are inserting your message.
There is another box below it for adding pictures (one picture per post).
My thought would be put it on a floppy (so you know exactly where its at).
Next to that box is a button that allows you to browse you disk for the image you want to attach to your message (I use .jpg files, won't accept some other types. And the size matters, if it's too big, it will be rejected but it will come back and tell you). Just double click on the image you want to use.
If you hit the preview button, you won't see the image. When you hit the post button, it will post and take you to the new post. At that point you can still edit the post by using the edit button in the lower right hand corner.
Hope this helps....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
