Old 12-05-2010, 09:04 PM   #1
CSoliz
Torn between 66 and 78
CSoliz's Avatar
My 04 Silverado is leaking above the gas tank.
I have no idea where this is coming from, maybe one of you could help me out. It is on the inner back corner of the fuel tank and it seem to be on the under side of the bed as well.
Any help would be appreciated, thanks.
CSoliz is offline   Reply With Quote
Old 12-05-2010, 09:19 PM   #2
truckdude239
truckdude239's Avatar
Re: My 04 Silverado is leaking above the gas tank.
that would be the pinion seal at the yoke on the rear dif. i bet if you reach under there and grap the yoke and drive shaft you can move it up and down mean the pinion bearing is wore out and will need to be replaced as will the seal
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-05-2010, 09:47 PM   #3
CSoliz
CSoliz's Avatar
is that a fairly simple job?
Old 12-06-2010, 08:19 AM   #4
truckdude239
nope require complete disassemble of the rear diff and a few special tools if the bearing is bad, if the seal you can remove the yoke and replace the seal but you have to get the backlash set back right on the yoke
David fuller
2000 Tahoe 5.3l 378
Old 12-06-2010, 09:32 AM   #5
white09
Werd.
Possibly a good time to look into a new differential carrier unit if you can spare the extra coin... perhaps a Detroit Truetrac
2009 Chevrolet Silverado ECSB 4x4
Top Gun Customz - Nitto - GM Assy
Dynomax - Airaid - SLP - Katzkins
white09 is offline   Reply With Quote
