Old 12-05-2010, 09:16 PM   #1
CSoliz
Torn between 66 and 78
CSoliz's Avatar
How did they lower my rear?
My truck is a 78 Big 10 shorty. My Uncle who owned it before me had a shop lower it and doesn't know how they did. I am not that familiar with leafs, if it was a 63-66 I wouldn't need to ask, but I need some schooling on this. It is supposed to be a 4" drop.
What ya think?
CSoliz is offline   Reply With Quote
Old 12-05-2010, 09:21 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: How did they lower my rear?
Is the front hanger reversed? You'll know because it will have bolts instead of rivets.
The leafs are below the axel. Stock, they are above the axel.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 12-05-2010, 09:25 PM   #3
JW76
JW76's Avatar
isn't that a flip kit? normally the leafs are on top of axle
JW76 is offline   Reply With Quote
Old 12-05-2010, 09:30 PM   #4
CSoliz
CSoliz's Avatar
it is, but I thought flip kits get you in the 6" drop range. Or am I wrong on that?
Old 12-05-2010, 09:27 PM   #5
CSoliz
CSoliz's Avatar
the hanger in the front is still riveted to the frame.
Old 12-05-2010, 09:27 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
It's had a flip kit installed.
The rearend is now on top of the leaf springs.
Probably a 5" or 6" rear drop.
Looks fine to me,... but I'm not sure about the red rubber snubber back by the rear shackle.
Keith
Convert to disc brakes.
Old 12-05-2010, 09:31 PM   #7
CSoliz
CSoliz's Avatar
I don't think it is dropped 5 or 6" though. Maybe I'm wrong, here is a pic of my truck.
Old 12-05-2010, 09:39 PM   #8
875.3CHEVY
looks like a bunch of leaf springs.i counted 8 that may be holding you up.is that part of the big 10 package.
875.3CHEVY is offline   Reply With Quote
Old 12-05-2010, 09:37 PM   #9
CSoliz
CSoliz's Avatar
would the snubbers take some of the arch out of leafs giving it less drop?
Old 12-05-2010, 09:43 PM   #10
CSoliz
CSoliz's Avatar
it may be, they call it a "heavy half ton". its GVW is about 6200. How many leafs does a regular 1/2t have?
Old 12-05-2010, 09:51 PM   #11
875.3CHEVY
mine has 5 mines bout that low but its flipped and has 2" rear shacles.
Old 12-05-2010, 09:44 PM   #12
joe231
joe231's Avatar
What size tires?
That is more than 4" in the rear.
I'm guessing somewhere in the 5"-7" range
Measure from the middle of the wheels to the top of the wheel opening front and rear.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-05-2010, 09:52 PM   #13
CSoliz
CSoliz's Avatar
they are 26" tall tires.
Center of the wheel to fender (wheel opening)
front 14 1/4"
rear 15 1/4"
Old 12-05-2010, 09:57 PM   #14
joe231
joe231's Avatar
that is a 5/5 drop
http://67-72chevytrucks.com/vboard/s...16#post4331216
looks like just a flip out back
CHEVY ONLY
Old 12-05-2010, 10:18 PM   #15
bigblock73
yeller
bigblock73's Avatar
Measure the leaf pack thickness at the axle, add 3" (axle tube diameter), and there is roughly your drop. You have bout a 6" drop due to the HD leafs in your truck
bigblock73 is offline   Reply With Quote
Old 12-05-2010, 10:57 PM   #16
CSoliz
CSoliz's Avatar
So how much lower can I go? and if I want to go lower out back I need to remove leafs and add shackles so I'm not to low, right?
Old 12-06-2010, 12:21 AM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
Any much lower and it will need a C-notch
Old 12-06-2010, 03:28 AM   #18
80stepsideguy
Laid back freak
80stepsideguy's Avatar
I wouldn`t go any lower then that, looks good as it is.I had a flip kit and a 2 inch bell tech hanger drop in the front and a shackle kit in the rear and it was way to low.I sold the bell tech kit and just did a flip kit and it sits level like yours and lowered.So unless you want to spend money you can do a air ride kit but thats all in your budget...
thanks
pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
