Old 12-05-2010, 10:00 PM   #1
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
help with starter/timing
hey guys i'm having a bit of an issue. i just replaced the old starter in my 70 blazer with a new skip white 3hp mini starter. i tried 2 shims, 1 shim, and no shims but it still grinds right as the motor starts. i also replaced the old distributor and upgraded to hei. my father has said the timing could be what is causes the starter to grind. it sounds healthy upon start all the way till it turns over but has a slight grind that i know shouldn't be there. any info or help is much appreciated. i did use the new bolts and the wires are correctly hooked up to the best of my knowledge.
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 12-05-2010, 11:31 PM   #2
cpetersen
cpetersen's Avatar
Re: help with starter/timing
I bought one and had the same problem. Did yours come with a body shim? It shim the gear away from the flex plate. I used the body shim and it noise went away. Mine was shattering when under throttle. The pinion depth was alright>
cpetersen is offline   Reply With Quote
Old 12-06-2010, 12:37 AM   #3
Sacramento70
Blazer Fanatic
what do you mean body shim, is it the the circular looking washer thingy thing that brings the gear a little more inwards?
1970 Chevy blazer
Old 12-06-2010, 01:42 AM   #4
cpetersen
cpetersen's Avatar
There is the one like the shape of the starter body and the washer one. It thats the starter gear away from the flex plate.
Old 12-06-2010, 01:50 AM   #5
cpetersen
cpetersen's Avatar
Pic is coming i had to find it. lol
Old 12-06-2010, 01:51 AM   #6
cpetersen
cpetersen's Avatar
Old 12-07-2010, 07:44 AM   #7
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I try to replace one thing at a time. What I would do is put my old starter back on and work out the distributor issue (or vice versa) and then add the other piece when I am happy with the installed one.
It gets confusing when I change more than one thing and have probs....
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 12-07-2010, 05:10 PM   #8
SeventyOne
That's good advice. If it were me I would double check I have the timing right then see if it still grinds. If it still grinds try the old starter. Still grinds - swap in the old dizzy and see where it put you. If it STILL grinds sell the truck.
SeventyOne is offline   Reply With Quote
Old 12-08-2010, 12:29 AM   #9
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
Starter needs to be shimmed to give specific clearance between starter and Ring gear. A paperclip will give you the correct gap between teeth/gears. Just get under the rig and engage the starter gear by hand and use the a straightened out paper clip to gap the teeth at the place they mesh.
The starter will make the most damaging sounding noise and hang up if not set up correctly, and will destroy the meshing teeth.
Shims may need to be used across both mounting bolts or just one depending on clearance required, one side shimmed will increase clearance and other bolt will decrease clearance purely a case of trial and error to get it right but providing the paperclip clearance is met you will have a sweet sounding starter. Check clearance in three different places on flywheel by rotating it.
Torrey72 is offline   Reply With Quote
Old 12-18-2010, 12:37 AM   #10
Sacramento70
Blazer Fanatic
so i found out the gear on the starter was bent and was shaking as it engaged the flywheel. i did manage to figure out the timing too, it was off by 1 tooth and as soon as i set tdc to #1 piston it fired up and purrs. I got the mini starter from skip white and let me tell you there customer service is great they have already sent a new one in the mail and were very polite and apologetic about my bad starter. ill let you guys how the second starter works out and my final opinion on skip white parts.
1970 Chevy blazer
