Old 12-05-2010, 10:59 PM   #1
tow guys
tow guys's Avatar
Where to find carrier bearing support??
I just picked up a 70 GMC wrecker in need of a full restoration. The first thing I would like to do with it is get it driving and stopping. She runs fine but needs brake work and a new center carrier bearing.
My problem is this-the entire mount for the bearing is rotted out. There isn't even enough to use to copy to make a new one. What are my options? Is this a part that is available in the aftermarket world? I have looked long ad hard but have had no luck. I also measured from u joint to u joint to consider a 1 pc shaft but it measures 84.5"! Yikes! Is that even possible??
Any help would be great. Thanks
tow guys is offline   Reply With Quote
Old 12-05-2010, 11:10 PM   #2
jayman68
Fun Stuff
jayman68's Avatar
Re: Where to find carrier bearing support??
Sounds cool, a wrecker. Try cpp for the carrier. Check out this thread,
http://67-72chevytrucks.com/vboard/s...d.php?t=384817
Good luck. Got any pictures?
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 12-06-2010, 12:26 AM   #3
tow guys
tow guys's Avatar
That's the carrier bearing all right but I am in need of the crossmember it bolts to. The factory part is riveted to the chassis but it's pretty much shot.
Old 12-06-2010, 01:54 AM   #4
jayman68
Fun Stuff
jayman68's Avatar
Does this look like the item you are looking for?
http://www.classicperform.com/Store/...ruck/CPSBB.htm
It might get you going in the right direction. Good luck.
Jay
68 C10(project)
88 Honda Accord(DD)
Old 12-06-2010, 02:27 AM   #5
swappy
I had a bracket once for the wider carrier bearing bolted right to the stock crossmember. Has anyone else seen one of these and what did they come on. The one i had was off of a 1972 gmc 1/2 with leaf springs. bolted right on my 72 chevy with coils
Rick
71 C10 long fleet sold
72 C10 short fleet
72 Olds cutlass
85 442
87 442
swappy is offline   Reply With Quote
Old 12-06-2010, 09:26 AM   #6
tow guys
tow guys's Avatar
Jay, that part is needed if using the lowered crossmember available at a number of places. It's an adapter plate of sorts. I need the portion of the chassis that it bolts to.
Thanks for lookin out!
Old 12-06-2010, 09:39 AM   #7
Todd68Chevy
Todd68Chevy's Avatar
I have a 67 C20 chassis I am parting out. I will try to look tonight and see which style it has. Do you need the whole crossmember or just the bracket?
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 12-06-2010, 09:47 AM   #8
tow guys
tow guys's Avatar
I need the entire crossmember from frame to frame. On mine, it seems to be riveted with 3 rivets on each side. Thanks
Old 12-06-2010, 09:49 AM   #9
tow guys
tow guys's Avatar
This is the part I need
Old 12-06-2010, 01:13 PM   #10
eagleuh1
eagleuh1's Avatar
That doesn't look stock.
eagleuh1 is offline   Reply With Quote
Old 12-06-2010, 01:29 PM   #11
dwragon
Just about any carrier bearing support from 60 to 72 will interchange (73 up bodystye will work also, subject to being open minded about modification, a simple peice of good thick channel iron will work.). Cut out the old rivits with a cold chisel and a punch, or grind or drill them out. I wouldnt use a cutting torch on the frame because its made of cold roll stamped steel and this made cause frame cracks later on. if you dont want to do that, cut the support about 4 inches from the frame and fab a new one in (I have used 1/8 thick (about) 1 inch square box tubing, drops into the chanel). or you can cut the old one out, pick a new location and drill new holes in the frame to mount it in. If you do this, use a small rat tail file (like is used on a chainsaw) and round out the edges where you drilled. On the factory frames, the holes were punched while the frame was still red hot, as well as the punching process making the metal around the hole denser. if you leave the edges square, they are subject to cracking.
dwragon is offline   Reply With Quote
Old 12-06-2010, 03:01 PM   #12
Papa Smurf
Active Member
I have a frame from a 72 C20 heavy duty(camper special). the cross-member looks nothing like what you show. It goes from top lip to bottom lip on both sides and the drive line goes through the cross-member with the carrier bearing holder bolting to the back of the cross-member. This is a leaf-spring truck, so no other brackets bolt to it. On a coil spring truck the rear arms bolt to this cross-member.
72 Sierra Grande 2500 BB
72 Sierra 2500, 42K miles, factory buckets
72 Cheyenne 20
72 Chevy SWB, Factory BB, Leaf Spring
Papa Smurf is offline   Reply With Quote
Old 12-06-2010, 04:22 PM   #13
tow guys
tow guys's Avatar
Here's a couple of pics of my setup. I assume this is stock?
Old 12-06-2010, 04:29 PM   #14
DT1
DT1's Avatar
That's some scary stuff!
Boy, am I glad my truck is from the California desert!!
DT1 is offline   Reply With Quote
Old 12-06-2010, 04:33 PM   #15
Todd68Chevy
I was not thinking about your truck being leaf spring suspension. I will look but my trucks are coil spring suspension and I am not sure if they have that style or not.
Old 12-06-2010, 08:34 PM   #16
bajaracing
bajaracing's Avatar
After upgrading engine/tranny, and trutrac re, I went thru 3 stockers. I then tried the CPP billet one. It's been 4 years now, never had that problem again. Call CPP, see if they have one for your setup..
bajaracing is offline   Reply With Quote
Old 12-06-2010, 09:39 PM   #17
Todd68Chevy
The cross member I have is for the rear coil suspension. Sorry
Old 12-07-2010, 09:15 AM   #18
Papa Smurf
Active Member
The one on my camper special looks like the one Todd68 is showing, except it doesn't have the brackets for the trailing arms and the carrier bearing bracket is magnum and bolts behind the crossmember.
72 Cheyenne 20
Old 12-07-2010, 09:34 AM   #19
tow guys
tow guys's Avatar
Sounds like I'll be fabricating something for this to work. No worries....we have the technology! lol
I found this on ebay. They claim factory nos for 67-74 GMC truck. Does this look right? Seems to look identical to what I already have.
Old 12-07-2010, 10:51 AM   #20
eagleuh1
eagleuh1's Avatar
Man, I haven't seen one yet that looked like m 68 C20 Custom camper with leaf springs. My hanger was riveted to the back top of the crossmember. The bearing was in a metal horseshoe that bolted two halves together. You just changed the rubber donut with the bearing in it out. Unfortunately couldn't find exact copy so replaced with NAPA. Had to use a square tubing spacer to move centerline of bearing back to right location.
Old 12-30-2010, 12:47 AM   #21
swappy
this is the one I was talking about[IMG][/IMG]
Rick
72 C10 short fleet
72 Olds cutlass
85 442
87 442
Old 12-30-2010, 01:21 AM   #22
tanman722001
tanman722001's Avatar
Never seen a braket like that one.My GMC have two carrier bearings in it and the braket is nothing like yours.i got one of my carrier bearings at NAPA for around $30.
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
