12-06-2010, 09:56 AM | #1 |
250 to 350 conversion
I just wanted to show the progress I am making in switching my 69SWB from a 250 to a 350. The 250 was original and ran great other then a small flat spot on the monojet between idle and acceleration. I got a good deal on a stock 350 which I have done the following: complete rebuild plus flat top pistons, edelbrock 2102 cam, vortec heads, BS serpenting pullys, SS Headers, Carter AFB 625cfm and all new external components. Also going with an aluminum radiator and dual electric fan setup.
12-06-2010, 10:27 AM | #2 |
Re: 250 to 350 conversion
sweet looking engine there!
12-06-2010, 12:19 PM | #3 |
No! Another 250 bites the dust...Ill take that power steering set up.
12-06-2010, 12:45 PM | #4 |
Big Red - Now its a SWB!
Both are great looking engines! let us know as you get closer, I can't wait for a video of that beast running.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-06-2010, 07:24 PM | #5 |
I love the pulley set up, who makes it, that the set up i need on my motor, what did they cost u, nice set up, looking good, keep on truckin'',
12-06-2010, 07:26 PM | #6 |
billet specialties produces this as a kit. set you back about $500 but it looks great and everything aligns perfectly.
12-06-2010, 11:45 PM | #7 |
Got a part number for the kit?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-07-2010, 12:19 PM | #8 |
Here is the part number directly from billetspecialties: FM2122PC
12-07-2010, 05:52 PM | #9 |
Nice swap you have thier. Both the motor out and in looks clean. Myself if i could swap my 68 lwb 350/400 for a straight 6 w/3 on the tree in a minute.
12-07-2010, 10:57 PM | #10 | |
Thanks for the information!! It will definantly be put on my "do" list..
12-06-2010, 08:13 PM | #11 |
Tot Roddin'
Nice looking update...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-03-2011, 08:23 PM | #12 |
I put a 350 in our 67 with 700r4 trans and moved stnds foward (which I got some V8 stands) and driver shaft seeems to fit perfect but yet to start truck.
01-04-2011, 10:42 AM | #13 |
The heads are both 062 (three humps). the single half moon you see on the d-side head is just whats on the opposite end of a 062 head . The 906 has a single hump thats similar.
01-04-2011, 01:14 PM | #14 |
"the other guy"
i have the "saw tooth" on both sides of my heads. only way iv ever seen them? also the heads are non-directional.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" Last edited by vasquezmrysvll; 01-04-2011 at 01:16 PM. |
01-04-2011, 02:58 PM | #15 | |
01-04-2011, 03:10 PM | #16 |
"the other guy"
just saying, the saw tooth is more desirable, if your builder advertised "vortecs" you should AT-LEAST get a matching pair, that flow the same numbers. goodluck
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" Last edited by vasquezmrysvll; 01-04-2011 at 03:10 PM. |
