Old 12-10-2010, 08:12 PM   #1
kenm78
Broken Down
kenm78's Avatar
Neutral Safety Switch Location
Ok, hopefully I'm not loosing my mind. I can not find my Neutral saftey switch. I have a 82 chevy K10 auto tranny. I looked inside on the steering column down towards the firewall where it bolts to the firewall. There is a cut out or opening in the column where it looks to go but I don't see it anywhere. The engine will not start in gear so it acts like it has one but I can't find it. Is it located somewhere else?
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 12-10-2010, 08:24 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Neutral Safety Switch Location
it could also be on the ignition switch its on top of the column close to the dash
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-10-2010, 09:14 PM   #3
kenm78
Broken Down
kenm78's Avatar
Anyone have a picture of this style of switch mentioned?
kenm78
1982 Chevy 4X4
Project truck
Old 12-11-2010, 12:07 PM   #4
flamingbig10
6.0 powered square
here what the switch looks like
Aaron
Old 12-11-2010, 01:42 PM   #5
kenm78
Broken Down
kenm78's Avatar
No picture attached
kenm78
1982 Chevy 4X4
Project truck
Old 12-11-2010, 02:28 PM   #6
GM72K10
Next!
GM72K10's Avatar
this is what one looks like for an 84 85 86
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-11-2010, 03:51 PM   #7
kenm78
Broken Down
kenm78's Avatar
Thanks. I remembered I had bought a used column so I finally opened the boxy and it had the switch I was looking for.
The end of the story is I wanted to get my back up lights working and couldn't find the neutral saftey switch. Everything I have seen or read indicates the back up light switch was intergrated in the neutral saftey switch. The switch I found looks just like a neutral saftey switch but only has two electrical prongs on it. It fits in my column and works great. The only thing I had to do was ziptie it in place becouse my column has clips that require it to be screwed in and this switch didn't have any moldings to fasten it down. Now I have backup lights! Thanks for pointing me towards the ignition switch becouse thats where the backup light harness was wrapped up hiding from me.
kenm78
1982 Chevy 4X4
Project truck
