dust shields with belltech 3" 73+ drop spindles?
Anyone running the 3" belltech drop spindles with the dust shields? What year dust shields are you using? Any modifications to the shield? What's the best place to order dust shields from?
My chassis came with the belltech spindles but no dust shields and I don't have any dust shields to check fitment. Thanks in advance,
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 12-12-2010 at 04:38 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: dust shields with belltech 3" 73+ drop spindles?
Any 73-87 dust shield will work.
Try to buy used ones,... new ones are pricey, ECE sells them new. I think they are available from your local GM dealer also.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-12-2010 at 04:46 PM. |
Yep, 73-87's.
Ok. Thanks. Are they a coated steel or aluminum? If aluminum I should be able to clean up a used one to look like new. If coated. It might be easier to just buy new... Looks like they're about $40 each from ECE.
Doug Looking for a 67-72 short bed driver..... |
They are steel.
Probably zinc plated. I would paint a used set.
motor exploder
I used CPP dust shields #CPDS-10, on my Western Chassis dropped spindles. They were $49 for the pair, zinc plated steel and bolted right up. They even came with the bolts.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
