Old 12-12-2010, 05:45 PM   #1
mexgrhd68
mexgrhd68's Avatar
Exclamation A-Arms
do the a-arms from 73-87 bolt right up to the 67-72? are they any wider than the 67-72?
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 12-12-2010, 08:13 PM   #2
Zeke
Active Member
Re: A-Arms
they bolt right up, don't think they are any wider, didn't check when I converted mine to disc, no issue.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 12-13-2010, 03:05 PM   #3
raycow
Re: A-Arms
The arms alone won't swap. You need to swap the shafts too. If you use the 73-up U-bolts on the lowers you will need to slightly enlarge the holes in the crossmember. Otherwise, everything fits.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-19-2010, 04:52 PM   #4
mexgrhd68
mexgrhd68's Avatar
Exclamation Re: A-Arms
Ray
can i use the 67-72 lower u-bolts to bolt up the lowers instead???
Old 12-13-2010, 03:13 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: A-Arms
The only difference will be the "rubber bushed" cross shafts and the balljoints.
Keith
Convert to disc brakes.
Old 12-16-2010, 03:26 AM   #6
mexgrhd68
mexgrhd68's Avatar
any pics?.....
Old 12-19-2010, 06:52 PM   #7
sameyrasmea72
sameyrasmea72's Avatar
Re: A-Arms
Originally Posted by mexgrhd68 View Post
any pics?.....
Here are some pics. The 73 and up pics are crappy but you get the idea. You can see the rubber on the 73 parts and the all metal 72. As far as the u-bolt the 73-87 ones work fine on a 72 front end like these. . The over all thickness of the bolt is bigger, but it fits the shaft and goes through the cross member fine.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-19-2010, 05:56 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: A-Arms
Interesting thread, sounds like an easy swap.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-19-2010, 06:01 PM   #9
Allensracing
Allensracing's Avatar
Re: A-Arms
its a simple swap, i have just never understood why someone would want the rubber bushings instead of the metal ones that come stock.
Allensracing is offline   Reply With Quote
Old 12-19-2010, 10:22 PM   #10
raycow
Re: A-Arms
How about: they last longer, they don't need greasing, they don't pick up dirt, they cost less and they are easier to find? Also, some people (but not me) say they ride better and transmit less noise/shock to the frame/body.
Most cars switched from metal to rubber bushings in the 50s. The trucks just took a little longer.
Ray
Old 12-28-2010, 01:24 AM   #11
mexgrhd68
mexgrhd68's Avatar
Re: A-Arms
cool...son is gonna bag his truck, switch to tubular a-arms, and i may transfer his arms from his 79 to my 68....already have new bushings installed also..
Old 12-28-2010, 07:53 AM   #12
Zeke
Active Member
Re: A-Arms
True 73-87 u-bolts work, they are bigger around and when I did my 69 thought I would need to make the hole bigger but after looking the new u-bolts they were spead apart just a little. Put a nut on one side and tapped it with a hammer against a 2x4 and fit perfect.
1969 C10 350 3spd
