12-14-2010, 03:40 PM | #1 |
Outer Heater Box hot air question?
There is a lot of hot air coming out around the hose where it meets the outer heater box. See pic below.
Will insulating the area with some spray foam get more heat into the cab of the truck? |
12-14-2010, 04:00 PM | #2 |
Re: Outer Heater Box hot air question?
i'd be carefull with the spray foam, you wont want to get a bunch inside. you could just silicone or caulk it . i believe there was originaly some sort of a foam seal . when replaced the cores in my trucks , i cut a small pieces of foam matting i had to squares about 2" with couple holes to put one the inlet/outlets .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car Last edited by 66skylarkpost; 12-14-2010 at 04:02 PM. |
12-14-2010, 04:01 PM | #3 |
it might help// but if the inside of the heater box is clogged up with 40years of crap there wont b much extra flow of heat into the cab
12-14-2010, 06:18 PM | #4 |
The Older Generation
I agree with Cliff. If you aren't getting a lot of heat out of your heater I'd be checking for debris or a mouse nest between the blower motor and the heater core... That would also cause excess air to exit around the tube. LockDoc
12-14-2010, 09:43 PM | #5 |
Sprayfoam and automobiles do not mix. As suggested [and just done to my truck after a 3 yr hibernation] clean out the heater box first then use something such as seam sealer[flexible], urethane sealer or butyl tape to seal the area around the hose. I would not recommend silicone as silicone attracts and traps moisture, remember this when considering silicone for any hole filling situations.
12-14-2010, 09:54 PM | #6 |
Ok, I just gooped some Silicone around it for now...
If I don't notice any difference I'll remove the box and see what treasures I find inside! For now the heat works well, I had noticed the amount of air coming out and thought the system might be improved if I insulate... Thanks for the tip Cheyenne Shortstep...I will note that in the future...I'd like to redo entire system in the future... I have seen some heating/cooling systems without the outer box...any info on these? the tubes plug straight into the firewall??? Thanks again! Last edited by nerve; 12-14-2010 at 09:58 PM. |
12-14-2010, 11:18 PM | #7 |
Cruzin
i used this kit from Classic Parts of America (Part # 68-765) on the 67 sealed everything up nice
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-15-2010, 11:43 AM | #8 |
What's the best way to get access to clean everything out? Is it better to remove the outer box in the engine compartment or take everything apart under the dash inside the cab?
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
12-15-2010, 11:56 AM | #9 |
You have to remove the outer box. You cant get to it from inside the truck.
to do this you will need to unbolt the passenger side hood hinge and slide it forward, carefully. I think there is also a bolt that is hard to get too because of the fender. The PO of my truck had broken the heater box flange at this location, so I didnt have to fool with that bolt. If memory serves me correctly, i think you have to drop the fender to get to it. Maybe someone else can chime in on that one. There also might be a FAQ or thread on how to remove it. |
12-15-2010, 12:00 PM | #10 | |
You can clean 90% of it by taking the heater box off of the engine compartment side. Then just blow some compressed air through the inside passages. You have to drop the inner fender panel down to get to a couple of fasteners on the bottom of it. You can probably get them off without dropping the inner panel but I've never been able to get them back on.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-15-2010 at 12:00 PM. |
12-15-2010, 12:02 PM | #11 |
Old Skool Club
Once you pull the front cap, it's not a big problem....
But, the nuts are on the outside (firewall), which attach to studs that are part of the inner heater ducting.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-16-2010, 02:50 PM | #12 |
On the 70 I just acquired, someone (don't know if it was factory) used a substance similar to plumber's putty to seal this area. As it was still pliable (after how long?) I used leftover PP from a kitchen project to reseal this area.
