rear end ratio?
I have 71 350 with a 3 speed. At 70 mph i am doing 3700 rpms which is rediculously loud. Id like some info on what gears i should run with if i were to change my current ones. I want to be able to pull something from time to time but i would still like something that isnt so loud. Any help would be great!
Grandpa in the rustmobile...
Re: rear end ratio?
Id say you have 373 lol me too it sucks going fast!
Maybe swap to 308 (Would be from a auto 1/2 ton 350 maybe)? Someone else is more knowledgable than me on this Or you can get a trans. with OD ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: rear end ratio?
My guess would be 4.56, if you've got 28" tires you'd be turning 3700rpm at 67mph, I don't know what size tires you have, but if they're slightly larger than 28" then that would get you your 70mph.
'68 C10 LWB 6.2NA/NP833 3.73's |
69' Chevy Stepside
![]() Join Date: Mar 2008
Re: rear end ratio?
You could swap in a 4 Speed Auto or overdrive unit instead of messing with the gears that way you get good highway cruising RPM and good acceleration/towing.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
Re: rear end ratio?
Sounds like 4.11 or 4.56.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Alright just checked i have 27 inch tires with a saginaw 3 speed on the column. i wanna do something about my tranny but i dont want to cut my floor for a different transmission that has more speeds, is there an over drive kit i can get for my 3 speed or somethin?
Re: rear end ratio?
There is a 'gear vendor od' whatever that is, not really sure..
I *THINK* there is a factory 3spd with OD but they are rare and pricey..
Re: rear end ratio?
There was a factory 3-speed with an OD unit attached to it. I believe it was only available on trucks up till 1968, though Chevelles and I think maybe full-size vehicles were available with it. It only came on lesser engines, in the case of trucks, only with 6-bangers. i think.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
Re: rear end ratio?
I have a 71 that came out with 3 speed on the column an a 307 with 12 bolt 4.11's in back.
Going to put an auto column an auto tranny in it in the next few months. |
Big Red - Now its a SWB!
Re: rear end ratio?
assuming your speedo is correct, it sounds like you have 4.11's. I would say if you want better cruise rpm and don't want to do OD then 3.08's would do it. Your off the line performance will suffer some though. Like stated above overdrive will give you better cruise, without the negative effects of higher gears. I have 4.56 in mine now and I can't stand cruising at higher than 60, I have a rear with 3.73's that I'm gonna swap in and after that I'm gonna do a OD tranny.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
sharp as a marble
![]() Join Date: Jan 2007
Re: rear end ratio?
go to this site:
http://www.hurst-drivelines.com/ and look for their RPM CALCULATOR Plug in the things that you know, and it will give you an idea of what you have. then plug in a 3.08 gear and you can see the difference. It might help you to be sure that you will get to where you want to go. |
its all about the +6 inches
Re: rear end ratio?
what size truck do you have? (C/10, 20, 30?)
What kind of tach you have? |
Re: rear end ratio?
Different online rpm calculators end up different sometimes. The boardmember raycow gave me this to figure it out.
I can't understand why different online calculators should give you different answers, but I always do mine with a hand-held calculator. The magic number is 20168. Divide your tire diameter into that to get tire revolutions per mile, and then multiply the result by your axle ratio. The number you get will be driveshaft revs per mile, which is the same as engine revs/mi if you don't have overdrive or torque comverter slip. As an example, let's say you have 31" tires and a 4.10 rear end, so: 20168/31 = 650.6 tire revs/mi 650.6 x 4.10 = 2667 2667 engine revs/mi. That is also your engine rpm at 60 mph. Other speeds are proportional, so if you want the engine speed at 70 mph: 2667 x 70/60 = 3111 rpm at 70 mph. Id say you have 4.11s or 4.56, most likely 4.56. If you switched to 3.08s youd be running 2684rpms at 70, maybe look at getting bigger rear tires when the time comes to change them out to. To switch rear end gears from what im hearing its best to switched just the whole rear end out. I hope this helps
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 12-16-2010 at 02:34 AM. |
Re: rear end ratio?
I have a c10 with a 5000 rpm tach. Ill do the math when I get back home but I can sure smoke my tires haha I appreciate the help!
![]() Posted via Mobile Device |
#15 |
Re: rear end ratio?
Alright heres my math-
20168/27 inch tires=746.96 tire revs/mi 746.96x4.10 gears=3062.54 engine revs/mi at 60 3062.54x1.17(70/60 rounded)=3,572.96 engine revs at 70 however my truck does 3700 rpms at 70 granted that it is right..so lets work backwards- 3700rpms@70 /1.17(70/60 rounded)=3162.39 rpms @ 60 3162.39/746.96 tire revs/mi = 4.23 gears 4.23 gears does that sound right? ![]() |
#16 |
Re: rear end ratio?
you probably have 4.11 rearend. When you calculate wheel diameter you need to use the actual rolling diameter. Mark the ground where the tire meets the ground and roll the truck forward or backward until the tire has made one revolution. Mark the ground and measure the distance between the 2 marks. It'll give you the true wheel diameter.
Retired Navy 1972 C10 Cheyenne fleetside 350 sbc, 700r4, 3.42 rear |
#17 |
Re: rear end ratio?
cant i just go 3.14 x diameter to get the circumfrence of the wheel
3.14 x 27=84.78 |
#18 | |
Re: rear end ratio?
#19 |
Re: rear end ratio?
I would get a better tach than a stock style one and recheck, or just pull the cover off the diff and find out exactly what you have in there.
I'm willing to bet a kick in the daddy parts you have something a little more normal like a 3.73 and your RPMs are more like 2900-3100 |
#20 |
Re: rear end ratio?
Check to see if theirs a tag on the cover first. Might still be there.
#21 |
Re: rear end ratio?
Is this a 3/4 ton truck? 2 wheel drive? The Dana axle would have had a tag between two of the bolts saying what the gear ratio was (or at least how many teeth on the ring and how many on the pinion), the Eaton does not in my experience.
Was this an original V8 truck? Any optional gear ratio would be on the SPID. Most likely a 6 cylinder 3 speed 3/4 ton would have had 4.57, but at 40 years old, who knows what has been swapped. The easiest way to lower your highway cruising speed is to put some taller tires on it. A 30"-31" tire will make a big difference, but not as much as you need. The next easiest would be a rear axle swap to something with much lower gears. 3.54 Dana 60 if a 3/4 ton or 3.07-3.42 if a 1/2 ton.
