Old 03-08-2003, 12:04 AM   #1
Mike Culpepper
Red
Mike Culpepper's Avatar
A/C'd and confused
I am looking to buy a '69-72 p/u and have a couple of Qs
with regard to A/C:
Where are the A/C "registers" (where the air comes out--register maybe the wrong term) on a '72? Are they UNDER the dash vs. IN the dash like several '69s I've seen?
I saw jmil74's 1969 p/u for sale and it has an A/C "register" that's under the dash and looks like a couple of the '72's I've seen. I am confused! I guess I want to know what a factory vs. an aftermarket or conversion type setup looks like on the '69-72 pickups.
Any help would be appreciated.
Mike C.
Mike Culpepper is offline   Reply With Quote
Old 03-08-2003, 12:07 AM   #2
Blue Beard
Blue Beard's Avatar
Mike
The factory air has a round ball on each end of the dash, and a rectangular located above the radio.
Most of the units I've seen below the dash are after market products...
Hope this helps..............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-08-2003, 12:24 AM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Factory AC for all models
The factory location is as stated below in the ends of the dash and above the radio.
Some dealers add on ac was under the dash units. You will notice the ball in the lower left hand side and above the radio and on the passenger side ball.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-08-2003, 12:32 AM   #4
mikep
Used to have a truck
mikep's Avatar
Chrome thingy in the middle and big balls on either side.
No truck :-(
mikep is offline   Reply With Quote
Old 03-08-2003, 05:38 AM   #5
GMCPaul
GM also offered 2 under dash A/C systems that were dealer installed options. The factory installed is the only one that had the vents in the dash.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 03-08-2003, 12:37 PM   #6
sam's 72
Mike,
You can also check out vintage air .com, they have units that install very nice, and you run the registers in the stock location. Just wanted to give you the heads up on this in case you come across a nice 67 - 72 without AC, You can put one of these units in it. Some of the guys on the board has them installed, also call them they will tell you how every thing fits
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 03-08-2003, 06:25 PM   #7
Mike Culpepper
Red
THANKS
I saw a '72 on e-bay that had vents below the dash and wasn't sure if it was "stock" or not. On the dealer installed units, is there a way you can tell that.....maybe on the glove box door?
I will check out vintage air and get an idea what it'd cost to add A/C, thanks again
Mike
Old 03-08-2003, 06:35 PM   #8
cleatussnow
cleatussnow's Avatar
I was told that this is a dealer install, I have not done the research to find out if it is true or not... but here ya go...
Cleatus
"What we are dealin' with here is a complete lack of respect for the law...." Beuford T. Justice
cleatussnow is offline   Reply With Quote
Old 03-08-2003, 06:36 PM   #9
cleatussnow
One more pic...
