1969 Custom 30 wrecker
Got a bent driveshaft (rear shaft) so I need to find a source for a good used one. This is on a 69 wrecker. Since this is a 1 ton with a 133 inch wheel base, what other trucks would use the same rear driveshaft?
Not sure if the longhorn's used a longer driveshaft or perhaps just a longer yoke? Also not sure if 1 ton had a special driveshaft compared to a 1/2 or 3/4 ton. Please educate me. ![]()
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 Last edited by bobs409; 12-19-2010 at 03:27 PM. |
the boat guy
Re: Driveshaft options for a C30 w/133 wheel base
if you put a used rear half of a 2 piece driveshaft into your truck you will have to have it ballanced by a driveline shop anyways. Why not just have them put a new piece of tube in your existing driveshaft and have them ballance that? Maybe more money initially but I'm sure it will save you a ton of time and probably some gas money.theirs alot to be said for doing it right the first time.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
