Old 12-20-2010, 10:50 AM   #1
colbyclay
after new carb, cannot get idle down without stalling [Solved]
Hello everyone,
I am working on rebuilding a 1971 C-10 with my dad. We recently put on a new Quadrajet Carb and replaced the points, condenser, coil, and distributor. (here is a link to my post on that):
http://67-72chevytrucks.com/vboard/s....php?p=4123824
Now, the truck turns over beautifully, but we had to set the idle to around 6000rpm! We set the points with a dwell meter, but when I try to back off the idle, it stalls out. I tried adjusting the idle mixture with the screws in the front of the carb, but that didn't have any appreciable change. Any ideas on what we could do to get it down to a normal idle?
Last edited by colbyclay; 01-04-2011 at 02:14 PM. Reason: added details, changed RPMs.
colbyclay is offline   Reply With Quote
Old 12-20-2010, 11:14 AM   #2
cdowns
cdowns's Avatar
Re: after new carb, cannot get idle down without stalling
could b a vaccume leak
Old 12-20-2010, 11:22 AM   #3
colbyclay
Originally Posted by cdowns View Post
could b a vacuum leak
I have a manual choke that has one vacuum line for the vac assist, then there are two vac inlets on the front of the carburetor that are capped. I have checked and none of them are leaking.
Old 12-20-2010, 12:21 PM   #4
haysonj
haysonj's Avatar
You need to spray WD 40 around the base of the carb and along the intake to see if there is a leak, you will get a change in rpm if there is. As far as idle rpm I don't know what engine you have but 600 is normal for the auto and 700 for the manual trans. on a V8.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 12-20-2010, 12:53 PM   #5
colbyclay
Great! Ill try that next time I am up there. I need to say though, I left a zero off the RPM. It is 6000, not 600. I would be really happy if it was at 600.
Old 12-20-2010, 01:07 PM   #6
haysonj
haysonj's Avatar
Your tach is messed up because a stock engine won't run to 6000 continuously. If it is running that fast you have the throttle stuck open.
Old 12-20-2010, 12:10 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
600 rpm sounds low to me.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-20-2010, 04:20 PM   #8
kevmic28
kevmic28's Avatar
If it were me I would take the new carb back and get it replaced with another. I have seen several threads on here where the new rebuilt quadrajet was junk.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 12-20-2010, 04:50 PM   #9
Wrenchbender Ret
Make sure the intake manifold, carb base, & gasket all match. There are variations in those years & if it all doesn't line up you have a horrible vacuum leak.
Wrenchbender Ret is offline   Reply With Quote
Old 12-21-2010, 04:54 PM   #10
Wrenchbender Ret
There is a large opening in the rear of the carb for power brake vacuum outlet. If you are not useing it put a 1/4 in. pipe plug in it.
Old 12-21-2010, 05:50 PM   #11
dadsworktruck
Ok let me see if i can follow what you did to this truck, it was running as per other posting, gas was leaking so you bought new carb, then with new carb it backfired and then you started replacing parts,eg...point, dist, cond, etc,,,,,am i close to correct? if so then your problem was the base gasket didnt match the manifold , which caused all your problems, now you will have to start over, pull carb off and match your gaskets to the carb and manifold, then you can go back to troubleshooting one item at a time.hope this helps.
dadsworktruck is offline   Reply With Quote
Old 01-04-2011, 02:14 PM   #12
colbyclay
And that solved this problem. Thanks Wrenchbender!
