What do I do next?
My 2000 5.3 has trouble starting especially when it is warm out. This is going to be hard to word but im going to do the best i can. The starter turns the motor over fine and is strong. When i hit the ignition i could hold it forever and it wont start, the starter turns the motor over fine but wont fire. If i bump it once then hit it again it fires well sometimes it takes 3 or 4, the hotter it is out the worse it is. When it is below freezing out it fires right up and the motor runs better in the colder weather also.
This has been pissing me off for a while and i have a new fuel pump, fuel regulator, fuel filter, plugs, and wires, whats next? Any help would be great! Thanks, Chad
1972 K20 lwb 2000 Z71 x-cab 1970 ford f100 |
#2 | |
Re: What do I do next?
i have seen them like this, and would also like to know the solution.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains ![]() Quote:
![]() want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
Hook it up to a scanner and see what codes its throwing. Some codes can be thrown and not show up on there. That will be your best starting point. Advanced Auto or Auto Zone do it for free. Post back the numbers here.
1985 Chevy K-20 350ci (8.1L in the works!) NP203/TH400 (Soon to be 205/400) Dana 44 and 14 bolt FF 7.6' Western Plow 2001 Silverado LT HD 4x4 496ci (8.1L) Allison EFI Live And more..... |
I hooked it up awhile ago and it said that it was running lean. I will get it scanned next time im in town and post the codes.
My 02 used to do something similar, but it was the fuel regulator that was leaking internally. I see that you swapped yours out already, where did you get it and could it be bad?
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
I got it at the dealer and when i pull the hose off it has plenty of vacuum. I haven't taken the truck in to get the codes read yet but plan on doing it soon. Its worse when it is warm out but when its cold it starts right up, could it be a mass air flow censor?
Auto parts stores do sell a cleaner for the mass air sensor, I do clean mine everyonce in a while. Worth a shot?
Slots go on anything!
I don't know if it will help, but try cleaning the throttle body too. The Vortec engines seem to be sensitive to this; they will idle really low (below 500 RPM) if the throttle body is dirty. The weather shouldn't affect this, but it sure wouldn't hurt, either.
1974 Jimmy- 5.3/4L80e/NP241 |
#9 | |
i agreee on that one too. with a dirty throttle body, you can watch your tach go nuts at an idle, and it will look almost like it has a miss.
Took it in to get it scanned and they couldn't pull a reading off it, they said something was wrong with the plug in. I checked all the fuses and they are all fine, also my damn horn and cigarette lighter don't work! Its colder than a witches titty out so i haven't gone out to really start looking for the problem, what is the the horn and cig ran to a relay or do i have a bigger problem?
The truck does sound like it has a miss at idle but its not very bad i will get to the throttle body when its not to cold out. The truck has 165k on it and i probably should have done this sooner!
![]() Join Date: Aug 2004
What possibly is happening is your injectors are leaking down and flooding the plenum. When you first use it during the day it fires right up, then after you have used it and shut it off, when you go to use it again you are getting hard starts wright. I have seen this before with my 2000 it was first diagnosed as a bad fuel pressure regulator, changed that but still had the problem, pulled the top of the intake and pressurized the system a wala 4 injectores were leaking 8 new gm injectors later and it was a lot of $ for them and problem fixed. Can not say for sure this is your problem but you could check into it if all else fails. John
![]() Join Date: May 2004
The diagnostic port is tied into the cigarette lighter circuit for whatever reason. Check that fuse again. Sometimes they look good, but are actually broken. Check the continuity on the fuse.
#14 | |
After checking this thread about 5 minutes ago i ran outside and checked the fuse center under the hood and found two popped 15 amp fuses for the cig and horn. My problem was i was checking the fuse block on the side of the dash.
Thank you everyone that has been helping diagnose my problem I will keep you posted on what i discover!
#15 |
![]() Join Date: Sep 2005
the cig lighret fuse is the same for the obd2 it is under the hood its a blue 15 amp or yellow 20 am towARD THE BACK OF THE BOX
#16 |
Got my truck scanned today and it said bank one and two was running lean and I have two O2 censors bad. They said the O2 censors are probably causing bank one and two to run lean. I do not think the O2 censors are the cause of my starting problem but i am going to put new ones in!
#17 |
You know, I have the same problem with my mom's 2001 suburban. It has been doing this for the past few months to a year now where in the morning I go to start it, it'll fire up on the first click, but after running and the shutting off the motor and then going back to fire up the motor it won't fire. It will just spin and spin and spin and won't start up.
It will take a few times to fire up and then you have to hit the gas to make it start. I don't know what the heck is wrong. The SES light has never come on either but I haven't checked if it has any stored codes either so. The truck has 137,000 miles on it. What should I do? |
#18 |
If the O2s are bad you should have a check engine light.
