Old 12-23-2010, 07:13 PM   #1
dwragon
old 2 ton 5 speeds
Im looking for some id info on old (55-65 or so) five speed tranmissions out of two ton or bigger trucks that will fit into a 67 one ton. Are these tranmissions reliable? I have one for a 409 that is huge and requires an adapter plate as it looks like the bell housing is part of the tranny, as well as two or three others.
dwragon is offline   Reply With Quote
Old 12-23-2010, 07:33 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: old 2 ton 5 speeds
Have you tried "Stovebolts.com"? It is a web-site that has a section for what they call Big Bolts.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-27-2010, 06:52 PM   #3
dwragon
I had not heard of that site, but will look there also. The transmissions I am looking for look the same as the ones in your 67 and 71 except they are five speeds. most of them came in dump trucks, buses, water trucks, or simular heavy tonnage.
Old 12-27-2010, 08:39 PM   #4
Dark Knight
Dark Knight's Avatar
Hey, a fellow Texan! I'm pretty sure these trannys were bulletproof. GM used these in all of the "big" trucks back then, usually with two speed rear axles. I know you had to "double clutch" them because they weren't synchronized. As for the ratios, I have no clue. I don't even know if you can find parts anymore. But it seems that these transmissions would be either Dana-Spicers or Eatons. My neighbor has a '59 GMC grain truck with one in it. It has an odd shift pattern.
It's something like:
1-2-4-R
__3-5__
I'll see if I can come up with something. It would be cool to transplant one into a 1 ton truck though.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 12-27-2010, 09:09 PM   #5
Dark Knight
Try this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=138323
Ha. "1969 GMC" has the exact shift knob on his avatar that I was describing.
Old 12-28-2010, 03:54 PM   #6
dwragon
Originally Posted by Dark Knight View Post
Try this thread:
This was the exact info I needed, Thanks a million.
Old 12-29-2010, 10:18 PM   #7
Dark Knight
Glad to help.
Old 12-27-2010, 09:35 PM   #8
Rob H.
Rob H.'s Avatar
I know some of the older trucks used a Clark 5 speed. I had a 49 3600 somebody had put one in, it was bolted up too a 235 6 cyl. though. Sorry can't be of more help.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
