12-25-2010, 08:41 PM | #1 |
Moderator
Heater Blower Motor Fan
I want to buy a Heater Blower Motor Fan, and possibly the blower motor. Mine is messed up where the shaft housing is pressed onto the fan. I need a good solid fan. Please let me know what you have, and price shipped to 95357.
Also, I would like the blower motor if it's an OEM and in good working order. Also, I would like it to be a good piece that can be cleaned and repainted to show quality. Please post a pic of the blower motor if you have one. Thanks!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 12-25-2010 at 09:18 PM. |
12-25-2010, 09:02 PM | #2 |
Re: Heater Blower Motor Fan
Pretty sure I have a OEM fan & motor combo in the parts shed stashed away. Will be tomorrow afternoon before I can check. Will look and see what condition it is in before I go any further.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
12-25-2010, 09:17 PM | #3 |
Moderator
Thanks! I guess I should add that mine is an Air Conditioned truck.
70 Longhorn CST Build Adding an AM/FM Decal |
12-25-2010, 09:24 PM | #4 |
Richard,
I'm pretty sure I have one in my garage that works and is in good condition. I will post some pics tomorrow when I get back home.
72 C20 Longbed 05 1500 Z71 |
12-25-2010, 09:25 PM | #5 |
Moderator
Thanks, Jorge!
12-26-2010, 07:36 PM | #6 |
Found the fan & motor combo I mentioned. Bench tested to make sure it works, runs smooth with no vibration or bearing noise. Motor body has no rust, just needs a fresh paint job to look really clean. The fan unit is nice with no missing or mouse chewed plastic blades. Still attached to the motor with original "push" nut retainer. Not sure if it is from a A/C truck or not, how can I tell, no part numbers on the motor housing? Fan unit is marked with a big " H " (Harrison, I think) and has # 3157437 on it. Can do pics if interested. Would do $30 shipped to your door.
12-26-2010, 10:18 PM | #7 | |
Moderator
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 12-26-2010 at 10:19 PM. |
12-27-2010, 05:49 AM | #8 |
Moderator
Jorge, what was it pulled from? Was it an A/C truck? Is the fan metal or plastic?
12-27-2010, 11:59 AM | #9 | |
It was pulled from a 72 C10 without A/C. The fan is plastic.
12-27-2010, 02:52 PM | #10 |
Sorry it took so long to post the pics, used up the digital batteries during Christmas and had to re-charge. I finally did find some lettering on the motor housing, says "Dayton, Ohio -- Delco Prod. -- USA" There are some other letters and numbers under the paint, looks like ***720 and " P - 12-70"
Would need to remove more paint for better look see. I "think'' the 12-70 shows mfg. date but not sure. Hope the pics are clear enough to show what you need. Let me know what you decide.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 03-22-2011 at 08:52 AM. |
12-27-2010, 10:29 PM | #11 | |
Moderator
Thanks!
12-27-2010, 11:55 PM | #12 |
Sorry but no hole or port on the side of the motor housing. If it will help I could drill you a hole in there if you would like. Guess I can't help you on this one. Nice try tho.
12-28-2010, 04:28 AM | #13 |
Moderator
Thanks guys. TTT, someone has to have one.
