Old 12-25-2010, 09:45 PM   #1
lilpoindexter
lilpoindexter's Avatar
2.5" spindles + 2" coil springs + flip kit
This is what my truck looks like with summit (ground force) 2.5" spindles, 2" DJM springs and a DJM flip kit. The flip kit pushes the wheel back in the opening so the driveshaft doesn't bottom in the trans...The rear wheel was already "back" a little, and the flip kit pushed it back even more...I'm going to have to do something, because it bothers me. Also, the spring plates are right where the shock extenders should mount..so instead of using all three spring extender bolts, i was only able to use 2.
It rides pretty nice, considering it's an old ass truck...It has Autozone cheapest shocks on it, and its a little nicer than before.
And ultimately...It's just not low enough...Ima start saving my pennies so i can bag this ****.
Oh...no c-notch, and I have to slow down on speed bumps, or else the front bottoms out.
lilpoindexter is offline   Reply With Quote
Old 12-25-2010, 10:07 PM   #2
87 chevy silverado
Re: 2.5" spindles + 2" coil springs + flip kit
looks good
87 chevy silverado is offline   Reply With Quote
Old 12-25-2010, 10:54 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A set of rally wheels and some nice fat lower profile tires would sure look great on there. The shorter tires might take away some of your desire to lower it further for awhile too.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-26-2010, 01:18 AM   #4
nbpro
Originally Posted by lilpoindexter View Post
The flip kit pushes the wheel back in the opening so the driveshaft doesn't bottom in the trans...The rear wheel was already "back" a little, and the flip kit pushed it back even more...I'm going to have to do something, because it bothers me. Also, the spring plates are right where the shock extenders , i was only able to use 2..so instead of using all three Oh...no c-notch, and I have to slow down on speed bumps, or else the front bottoms out.
I was just wondering if this was something common.
nbpro is offline   Reply With Quote
Old 12-26-2010, 01:24 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Yeah or shorten the drive shaft.
Old 12-26-2010, 01:32 AM   #6
nbpro
so its common.to have to shorten the drive shaft. with a flip kit
Old 12-26-2010, 01:35 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
No, its not common. It's possible that lilpoindexter put the saddles for the leaf springs in wrong. The flip kit should not move the axle back that far.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-18-2011, 01:22 AM   #8
mcboomport
mcboomport's Avatar
I was thinking the same thing.
mcboomport is offline   Reply With Quote
Old 12-26-2010, 01:38 AM   #9
nbpro
that is what i was thinking lol hole goes to the front right ?
Old 12-26-2010, 09:36 AM   #10
Tx Firefighter
I've put in a lot of Beltech flip kits and all of them had the hole offset about 1/2 an inch or so. Never had to mess with driveshaft length.
Old 12-26-2010, 06:55 PM   #11
slugish
Slugish
TO EACH HIS OWN ON LOWERING , BUT i LIKE YOUR STANCE AS IS
slugish is offline   Reply With Quote
Old 12-26-2010, 07:55 PM   #12
1LowToy
I just came in and lit the fireplace, it's cold out there laying on my back and cutting off the rear bump stops. Burrrr. Any way Ive seen some trucks with the axle back like yours and it really doesn't look right. I was wondering of you may have the springs in backwards, or is that normal for flip kits?
1LowToy is offline   Reply With Quote
Old 05-17-2011, 11:53 PM   #13
sduckworth13
sduckworth13's Avatar
just checking out your thread, I like the look of your truck.
sduckworth13 is offline   Reply With Quote
Old 05-18-2011, 12:14 AM   #14
lilpoindexter
Thanks man
Old 05-18-2011, 01:22 PM   #15
TIM86
TIM86's Avatar
Looks great! I really want to get mine lowered (still saving). I was looking at that same kit.
TIM86 is offline   Reply With Quote
Old 05-18-2011, 10:52 PM   #16
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
so what was the total drop for this.....also, shouldnt the back end be more even with the front for stance?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 05-19-2011, 10:39 AM   #17
mooseknuckles
mooseknuckles's Avatar
that would look sooo sick bagged man!...get that big rear bumper draggin on the ground!
mooseknuckles is offline   Reply With Quote
Old 05-21-2011, 12:38 AM   #18
lilpoindexter
DUDE...you don't know how many times I've dozed off to sleep with thoughts of sparks and scraping sounds off the back bumper....
Old 05-19-2011, 11:20 AM   #19
mcboomport
mcboomport's Avatar
Its a 4.5"front and 5" rear. Who's to say what type of stance the truck is supposed to have? To each their own.
Old 05-20-2011, 10:35 PM   #20
ProStreet83C10
Drag Racer
I didn't mean it that way at all. I just figured it'd be more leveled Ghana what it is hence the reason I asked what total drop was
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 05-21-2011, 08:52 AM   #21
Cherub
Cherub's Avatar
thats the stance i go for, Looks good. there are plenty of reasons why not all drops come out exactly alike.
Cherub is offline   Reply With Quote
Old 08-05-2011, 08:23 PM   #22
moose666
hey was just wondering if you had any issues with bolting up the rally rims with the dropped spindles. cause i cant run them they rip into the lip of the rim. the other thing is how did the ride turn out????? i am running 2" dropped spindles and 1" dropped coil and it rides like **** soooo stiff.
thanks for your time
moose666 is offline   Reply With Quote
Old 08-05-2011, 08:36 PM   #23
rwhit57
rwhit57's Avatar
This is an older post, but with drop spindles you might have to trim the lower control arm to get 15" wheels to fit. Just don't get into the radius. Also I noticed this guy said his front bottomed out. You have to cut the bump stop pads off the lower control arm or it will ride like s***t.
rwhit57 is offline   Reply With Quote
Old 08-05-2011, 09:03 PM   #24
lilpoindexter
No issues with clearance on the front wheels...they are 6.5" van rallys and the spindles are only 2.5"...I figured out what my bottoming was...I had the stock shocks on like a dumb ass...I got the shortest drop shocks summit racing has for square bodies, and my bottoming problem went away. With the big ass 235/75/15's in the front, If I don't slow down for mongo speed bumps the tires will touch the tops of the inner fenders...but it has to be a big bump, and I have to be hauling ass. I also re-drilled my rear flip brackets when I got a new driveshaft, so the rear wheels are centered in the wheel well. If I did it again, I would keep the stock springs, instead of 1" drop springs so that the truck would be more level front to back, and so I could still hit speed bumps without slowing down at all. The ride is frankly, pretty nice, for a lowered 33 year old truck.
Old 08-06-2011, 10:23 AM   #25
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Wait, did you get 1" drop coils or 2"? I was considering the exact drop components you have in the title, so this thread is of great interest to me.
Whatever you did, the drop looks great.
killthewabbit is offline   Reply With Quote
dont touch my junk!!!
