Old 12-25-2010, 11:34 PM   #1
ortega
modulator vacuum line.
Sorry I messed up the last post.
My trucks line from the modulator is going to the back of the carb. Could this be the reason y it doesn't shift right. I've seen that the line should go to the intake, could I tap my edelbrock intake and put some connector in there. The engine and tranny are a 454/400 that came out of a 89 tbi r3500.
ortega is offline   Reply With Quote
Old 12-25-2010, 11:46 PM   #2
JuicyJ
JuicyJ's Avatar
Re: modulator vacuum line.
Mine is tapped off of the intake and I have never had a problem. Shifts fine, you should be okay.
America is all about speed, hot nasty bad ass speed
JuicyJ is offline   Reply With Quote
Old 12-26-2010, 12:09 AM   #3
benoit454
Chris
benoit454's Avatar
factory they come off the intake, I got one right now off the back of an edelbrock carb and it works fine.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-26-2010, 02:14 AM   #4
ortega
should there be vacuum at that port at all times? when i disconnect the line at the carb i dont feel any vacuum.
Old 12-26-2010, 02:20 AM   #5
csb#356
You might have it hooked to ported vacuum. What carb do you have? usually the one at the back is full vacuum. I have always had better luck with hooking the modulator line to the intake and then hook your other accesories to the carb. I don't think you should need to tap the intake though, there should be a hole already there and its probably plugged with a bolt. Another reason it may not shift is the kickdown linkage may not be adjusted right.
csb#356 is offline   Reply With Quote
Old 12-26-2010, 02:55 PM   #6
benoit454
Chris
benoit454's Avatar
there should be vac. at all times, it's manifold vac. so it's all times. if there is none you need to change it, although ported creates vac. right off idle so it should work too but I always use full manifold vac.
If you have the fitting or plug and can remove it use the intake fitting it should be on the PS behind the cab, in front of the dist. My problem was they are always messed up and won't come out or afraid to crack it or something so I just t-'d mine off the back of the carb and used th eother side of the t for power brakes, never had a problem with it.
Chris
GIT R DONE!!!!!!
Old 12-27-2010, 12:28 AM   #7
ortega
i didnt know what the plugged port on my intake was, so i guess ill buy a fitting and get the vacuum from there. Since csb mentioned the kicked down i looked for it and found out the truck doesnt have anything. no linkage or switch.
Old 12-27-2010, 01:06 AM   #8
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
yeah its a 400. if you swapped it in your truck then you need to add the switch under your gas pedal i think for the kickdown.
heres the switch:
http://www.americanclassic.com/Googl...70NOS-1973.htm
it mounts to the accelerator pedal mounting bracket, you can find them in the junkyards sometimes. you can pull the wiring there, but it is only one wire and just needs 12v, pretty simple.
b7m also make a kit that adapts to the throttle linkage, pretty nice if your willing to spend $50 for it because you can adjust it to kickdown before you hit WOT
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
Old 12-27-2010, 01:33 AM   #9
ortega
cool, i'm gonna hit the junkyard after work and see if i find one, i could look for a window switch connector while im there since i need one too
