12-26-2010, 12:02 PM | #1 |
Location: AZ City Arizona............................My page is still construction by a pack of sick stray cats.
Rear end swap
I have a 69 GMC 3/4 ton flatbed that is mostly a work truck but I need to be able to go free way speeds. It currently has a 4.56 rear end in it with a 3 speed with a granny standard trans. I want to try to keep the trans because it comes in handy with and many jobs we have for it. Looking for suggestions as far as if there is a easy swap to a different 3/4 axle. I've also looked at a different ring in pinion but I can only go down to a 4.11 without changing the whole carrier.
12-26-2010, 02:54 PM | #2 | |
Re: Rear end swap
3/4 ton trucks just had lower gears back then, you are not overly likely to find anything a whole lot higher.....of course it will depend upon which axle you actually have and whether is is coil or leaf.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
12-26-2010, 03:10 PM | #3 |
Re: Rear end swap
If you want to keep the 3/4 ton axle i cant see it being easy or cheap to switch it out. What size tires do you have? That may be your best bet.
1969 Chevy c20(Miss Hackjob) |
12-26-2010, 03:12 PM | #4 |
its all about the +6 inches
Re: Rear end swap
dana or eaton
leaf or coil? |
12-26-2010, 03:24 PM | #5 |
Big Red - Now its a SWB!
Re: Rear end swap
Same questions I was gonna ask.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-26-2010, 07:22 PM | #6 |
"brand new second-hand"
Re: Rear end swap
I changed out the rearend on my 69 to a 14bolt semi floater with 3.23 gears by using CCP brackets and panhard bar. The rearend came out of a 1986 3/4 ton truck with leave spriings and I converted it to coil with the brackets. Works great for me, I can actully keep up (80+) on the freeways!
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
12-26-2010, 07:29 PM | #7 | |
Re: Rear end swap
12-26-2010, 07:47 PM | #8 |
Future TOTM Winner
Re: Rear end swap
The 14b semi-floater came in 6 lug and 8 lug versions (along with a few different width options). Also, there is an ultra rare 5 lug version that came in the mid 90s model 454ss trucks.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
12-26-2010, 10:34 PM | #9 |
Re: Rear end swap
Why would one want a semi floater?
12-27-2010, 01:28 AM | #10 |
Re: Rear end swap
I considered one so that I wouldn't have an ugly hub sticking out of the wheel, but other than that there is no good reason that I can see.
12-27-2010, 06:08 PM | #11 |
Re: Rear end swap
I choose it mainly for the gear ratio-I wanted to get the best gear for the highway I could find. If I had it to do over again, I would have gone with the 14 full floater and been satisfied with a 3:54 or 3:73 rear gear. Now I have too much money in the rearend I choose to get rid of it It works fine for what I need. Unless you are really hauling heavy loads, this should hold up and I could probably get higher gear ratio if needed.
12-28-2010, 08:57 AM | #12 | |
Re: Rear end swap
12-31-2010, 08:59 AM | #13 | |
Re: Rear end swap
What trucks should I look for to get a 3.54 ratio full floater? I think this would work fine, the truck is still going to do some heavy work so I don't think I want to go semi. |
12-27-2010, 03:53 PM | #14 |
Re: Rear end swap
Its leaf spring with the original dana axle
12-27-2010, 03:56 PM | #15 |
Re: Rear end swap
My truck cruised around 80mph with the stock drivetreain all the way home the day i got it(350mile trip back)with i think a 4.56 rear gear... the rpms were a little high but it handled great
12-28-2010, 08:54 AM | #16 |
Re: Rear end swap
How much is a little high? Mine looks like it will be running about 5000. I have a friend that had the same trans and rear end ratio and he drove it 75......... but also spun his main bearings.
12-31-2010, 09:45 AM | #17 | |
Re: Rear end swap
12-27-2010, 06:12 PM | #18 |
Re: Rear end swap
when I was in High School a Teacher had an old 66 chevy that had an 5 speed tranny in it out of an old school bus , when I talked to his son about it seemed to work good an keep the hiways Rpms low !
12-28-2010, 10:47 AM | #19 |
Future TOTM Winner
Re: Rear end swap
Here is a great tool for figuring out what you want to do. I like the fact that you can compare two setups side by side. The trick in my opinion with any of these calculators is to be accurate with the tire sizing. Don't go by what is stamped on the the sidewall. Get a tape measure and measure from the ground to the center of the wheel hub, then multiply times two to get the effective tire diameter.
http://www.grimmjeeper.com/gears.html
12-31-2010, 10:29 AM | #20 |
Re: Rear end swap
3.54 was in the 3/4 ton dana rear. If you plan on working your trucks hard with a lot of weight, I don't recomend it. The axle shafs tend to shatter.
11-08-2012, 04:53 PM | #21 |
Re: Rear end swap
To go freeway speeds the rear end almost has to be changed. I switch my 4.11 rear end for 3.38. But it is a 1/2 ton sorry.
I pity the fool with only 2 headlights! |
11-08-2012, 05:00 PM | #22 |
Re: Rear end swap
11-08-2012, 09:56 PM | #23 |
Re: Rear end swap
Oh yeah, bringing up some old stuff.
03-07-2013, 12:32 AM | #24 |
Re: Rear end swap
Put a 3.54 rear end in today. Here we are doing the brakes on the back of the truck before install. Fit like a glove, my son did most of the work and he is awesome!
Tags |
help axle ratio economy |
