Heated seat shutting off... what I found...
2004 TAHOE Z71
I've seen alot of talk online about this with little solutions offered so I thought I'd share... My drivers side heated seat would shut off if the butt warmer was engaged (seat BACK only funtion still worked) I remove the screws holding the seat position controler, removed the two connectors and set the controler aside... Then I pushed down on the plastic retainers holding the seat cushion on the left side, front and right side at the bottom of the seat frame. Then I folded the cushion and cover away from the seat frame. Next I seperated the leather from the cushion (velcro'd together) and found the seat heating element burnt to a crisp! The element is held down by sticky tape... (try not to take too much foam with it!) It appears that it wore out from flexing right at the seams of the seat cover. Here's the part from gmpartsdirect.com.... GM PART # 88940288 CATEGORY: All PACK QTY: 1 CORE CHARGE: $0.00 GM LIST: $138.85 OUR PRICE: $80.73 Guess I will be ordering that now and will let y'all know how it works!
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab Last edited by allengator; 12-26-2010 at 05:48 PM. |
Big Red - Now its a SWB!
Re: Heated seat shutting off... what I found...
Looks like you are lucky that your butt didn't get really warm!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
