Old 12-27-2010, 12:31 AM   #1
my70chevyc10
my70chevyc10's Avatar
dead battery
so i go to start my truck that i havent driven sence friday night and the battery is dead. the only thing that has changed is i had to run a new wire for my plower motor because the wire that goes behind the fuse block was bad and i installed a new sterio in my dash. the new wire runs stright to the battery and so does the radio.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 12-27-2010, 02:51 AM   #2
Tmend
Tmend's Avatar
Re: dead battery
I had a similar problem once. I installed a new radio in my 67 only to find the radio had a short that caused a 750ma draw that drained my battery after sitting fo 2 days. Drive ur truck around then if possible park it for 2 days after removing the stereo power wire don't worry about the blower it requires no power when not in use. Then try and start ur truck.may isolate the problem.
Tmend is offline   Reply With Quote
Old 12-27-2010, 10:49 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: dead battery
your radio have presets or a clock? If wired wrong it will kill the battery
