Shaved Firewall Question ????
This is prolly a dumb question but I have seen a lot of people shaving the firewalls on here . What do you use for heat if you take it all out and shave it ? or do you just not drive your truck when it's cold ? I plan on driving mine as much as possible so I'm gunna want some heat lol
Re: Shaved Firewall Question ????
I have used both a rear bus heater and a motorcycle radiator in the past with the hoses running through the floor and up through the kick panel. Worked great in with both, a small motorcycle electric fan worked great too.
![]() Join Date: Jun 2006
I shaved the firewall, and for now have no heat or air. I plan to eventually buy a under dash unit with heat and air. If you don't need the air, you can buy heat only units. I got an idea for another board member, LFD I think, and plan to run a pass thru bulk head in the area below the right kick panel vent and have the lines/hoses come in there. Trying to keep things hidden.
You could also just get a nice billet pass thru bulk head and stick over on pass side firewall area to route hoses.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
SheetMetalNoob
![]() Join Date: Jan 2010
Geoff Clark Classic Truck NoOb 83 Chevy Custom Deluxe I6 250 lwb (aka) Trash Runner |
JUST KEEP IT ORIGINAL it will be easier
