Old 12-30-2010, 08:30 PM   #1
DeputyDan
Rear End Gear identification
can anyone tell me the best way to id what rear end gears I have in my truck. I'm assuming it's stock (72 Chevy Cheyenne Super) but have no idea what stock gears are. I looked under the truck today but couldn't find any numbers. Am I overlooking some type of id numbers somewhere? I am looking at upgrading to a 350 350hp 385tq and want to see if my current rear end will jive with that. Anyone have any suggestions?
DeputyDan is offline   Reply With Quote
Old 12-30-2010, 08:34 PM   #2
jakeblues652
jakeblues652's Avatar
Re: Rear End Gear identification
so theres 2 main options. either take the diff cover off, or theres a way you could jack it up and count the turns of the tire and drive shaft, but im not totally sure what that procedure is, but i bet someone would be glad to give you it!
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-30-2010, 08:42 PM   #3
Sicklajoie
The Niner
Sicklajoie's Avatar
Mark the driveshaft. While turning the wheel one full revolution, count the number of times the driveshaft rotates and that's your ratio. A little over 4 driveshaft revolutions to one wheel revolution would be 4.11's.
Sicklajoie is offline   Reply With Quote
Old 12-30-2010, 08:47 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Assuming it's not posi, you have to turn the wheel 2 complete rotations and count the driveshaft revolutions.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
