Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-30-2010, 10:03 PM   #1
chevyndn
what gasket sealer works best?
i have been having problems gettin my water pump in my 97 blazer to seal right... ive tried the permatex black gasket maker and im havin no luck. i seem to keep blowin the gaskets out. when i change the water pump in my 98 gmc i never had this problem, but it think i used a different gasket sealer. i cant remeber what kind i used on that truck. any help on what everyone uses would be helpful. im gona try another water pump and new gaskets this weekend thats why i was wondering.
chevyndn is offline   Reply With Quote
Old 12-31-2010, 01:56 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: what gasket sealer works best?
right stuff
http://www.oreillyauto.com/site/c/de...rd=right+stuff
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-31-2010, 09:02 AM   #3
xflyboy
xflyboy's Avatar
one the best going right there, but I would check to make sure that ABSOLUTEY all the old gasket is off the block first (a good scraper and then sandpaper or a gasket removal pad http://multimedia.3m.com/mws/mediawe...SevTSeSSSSSS--)
if even a small peice remains it will let the pump sit off enough to allow a path for leaking to occur. I may not change them everyday but I've sod enough and seen this before to know a common solution. And yes even the professional rush tgrough the simple job and have this issue sometimes.
just a paint guy working hard and driving GMC's
xflyboy is offline   Reply With Quote
Old 12-31-2010, 04:18 PM   #4
Sillyoldman
#16876
Sillyoldman's Avatar
Originally Posted by Warrens69GMC View Post
Thats what I was going to reply. Be careful with it though. You may ruin some parts if you later need to remove them.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 01-03-2011, 07:27 PM   #5
chevyndn
well i got it takin care of, i think my old water pump had a crack in one of the bolt holes case it was all messed up right there, but that water pump gave me problems since i put it on last year. i got a new one with lifetime warrenty on it and seems to be ok now. thanks for all the input!!
Old 01-03-2011, 10:48 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The last sealer you'll ever use!! I use it on intake gasket bolts. No oil seepage anywhere.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
