Old 12-31-2010, 01:36 PM   #1
air12fwk
NEED Some guidance
I have a 1968 C20 3/4 ton 292 engine. I replaced the water pump and turned in the core bofore I found I had a problem. The water pump pully only lines up with the altinator pully. The main crank is duil pully. The water pump pully is 1 1/4 inches short of lineing up with the inside crank pully. The preveus owner admitted doing some compermising when replcesing ether the altinator of the water pump prevouisly. I would say it was the altinator. The main crank only runs the water pump and the altinator. What He did was cause the bearing in the water pump to fail by not haveing the pullys lined up rite in the first place. Finding a shallower water pump pully would work. Duil pully on the altinator will not work. ANY SUGGESTIONS FOLKS This is a very collectible engine and junk yards KNOW IT. THANKS
air12fwk is offline   Reply With Quote
Old 12-31-2010, 07:15 PM   #2
john
member #16
john's Avatar
Re: NEED Some guidance
to the board. Some pics of the problem will help.
john is offline   Reply With Quote
Old 12-31-2010, 07:21 PM   #3
eyebuzz
Licensed driver
eyebuzz's Avatar
Yes, Welcome!
I like to see more posts in the Suburban area - but you will definitely get more answers from the regular 67-72 Truck forum (just more people looking at it) - also there is the general engine/drive line forum on this board too.
TT
eyebuzz is offline   Reply With Quote
