12-31-2010, 08:39 PM | #1 |
52 Chevy Build
Okay guys thanks to OrrieG for helping me figure out how to post this thread, I have a 1952 Chevy Truck that I am going to build, Right now I am gathering parts like front sub frame from a Camaro (81 Z28) I got the whole car for $100.00 bucks lol...
I have a lot of questions for you awesome builders, #1. how do you know exactly where to cut the frame when doing a sub frame conversion? I have seen some awesome pictures for this build but not a lot of detail on where to actually cut at so any info and pictures would be very helpful. I will ask my next question tomorrow, I am going to pick my truck up in the morning because the cold weather has finally given us a break here in Eastern, Ky and I will have new pictures of what I purchased. Joey http://www.electronicshve.com |
01-01-2011, 07:56 PM | #2 |
Re: 52 Chevy Build
I assume you are posting pics of the truck you are planning to work on. My question to you is this. Why do you want to change the front sub frame?
From what i see from the pics you provided, the truck is a 3/4 ton 4x4. It looks to be sitting on a newer frame from what i can tell. The only reason to change the front sub frame is if the truck is a 2wd and has the orginial frame and suspension under it. This would than tell me you are planning to upgrade the front, hence the purchase of the camaro. I don't see how this would work with the 4x4 frame, unless you plan on converting it to a 2wd truck. I would keep it the way it sits, it looks great as is. I wouldn't mind owning it myself as I like the looks of these classic trucks. |
01-01-2011, 08:12 PM | #3 |
Re: 52 Chevy Build
Thanks for the post, actually frame under this truck is original, someone cut the 2wheel suspension out and upgraded it to be a 4x4, after researching the sub frame idea i have found i am better off going with an older sub frame from the 78 to 81 camero, i like this 4x4 look but i want it to be 2 wheel instead plus i am thinking of going with a short wheel base bed
01-01-2011, 08:48 PM | #4 | |
Re: 52 Chevy Build
01-02-2011, 09:36 PM | #5 |
Re: 52 Chevy Build
At least i now know what you want to do, it's a nice truck. You don't see too many that are 4wd's. A friend has one sitting outside at his shop that i would like to great my hands on, but would require too much time and money to make it the 4x4 i want.
Are you planning to cut the frame down to a swb or just find one that is? What's all there for a drivetrain anyways? |
01-02-2011, 10:40 PM | #6 | |
Re: 52 Chevy Build
