Old 01-01-2011, 11:05 AM   #1
8door
Not too old to learn
Cool Non stock tach
As the stock factory tachs seem to get high prices, I wanted to see what you all install that fit in the opening, but are less expensive.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 01-01-2011, 03:35 PM   #2
Indyuke
Re: Non stock tach
I've heard some 80's camaro's will work.
Indyuke is offline   Reply With Quote
Old 01-01-2011, 03:57 PM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Non stock tach
8door,
Check out this members thread on doing a tach conversion with a Camaro Tach. Said he got the tach on ebay and it was from a '72-'78 but says he has heard anywhere from '70 to '81 will work. Check it out:
http://67-72chevytrucks.com/vboard/s...d.php?t=251017
Good Luck
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-01-2011, 09:45 PM   #4
8door
Re: Non stock tach
That's good info.
I also just went on ebay and found several listed for Camaros
at under a $100 low as $60.
And that keeps the overall look the same and is Chevrolet.
Old 01-01-2011, 10:12 PM   #5
myoldchevytruck
Re: Non stock tach
yep, it sure does. i was gonna go the camaro tach route and then i got lucky at the carlisle spring show in pennsylvania, i found factory gauges with a tach. the bezel was cracked pretty bad. I gave the guy $40.00 cash and walked. I have since rebuilt it and cant wait to put it in my truck. good luck on you tach gauge build.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
