01-02-2011, 02:16 PM | #1 |
Oil Pressure Line
Hello
Just to confirm. Does the oil line kit from Classic Parts complete the connection from the engine block to the gauge? I believe it does but not sure to order it up. One person told me to go electrical. I am trying to keep cluster original Lewis http://www.classicparts.com/1947-77-...ctinfo/24-781/ Last edited by cobra1966; 01-02-2011 at 02:17 PM. |
01-02-2011, 02:19 PM | #2 |
Re: Oil Pressure Line
Yes it goes straight from the block to the cluster.
01-02-2011, 02:24 PM | #3 |
Thanks for the help. I knew someone knew the right answer. My father and I are new to the 1972 Chevy Truck C-10. We are learning as we go. I am glad for this forum and Chevy Guru's
Lewis |
01-02-2011, 02:33 PM | #4 | |
69 Chevy 4x4 383 Power |
01-02-2011, 02:48 PM | #5 |
Ok. I was thinking I have to order it up. I will look into AutoZone since thats where the old man likes to shop at. I should be able to find it there or else where like pepboys...
Thanks Lewis |
01-02-2011, 02:54 PM | #6 |
http://www.classicindustries.com/con...ch&keyword=oil pressure line&productSearchCatalogId=4&productYearId=118&sortOrder=1&sortBy=1&listAs=1¤tPage=1
The link shows 3. I have a 1979 Chevy 305. Which of the 2 should I order if I dont find a good one? I am thinking the small block in middle. Any suggestions? Lewis |
01-02-2011, 02:57 PM | #7 |
Yea just go to Auto Zone they should have it in stock thats where I got mine for my 72.
01-02-2011, 02:57 PM | #8 |
U.S. Army Green Beret Sniper
The original oil pressure line are hardlines. Installed on the rear part of the engine just on the left hand side of the distributor. I just replace my sons yesterday............
"YOU CAN RUN AND YOU CAN HIDE, BUT YOU WILL JUST DIE TIRED" |
01-02-2011, 03:01 PM | #9 |
Pay careful attention to the fittings in the picture. They are special and not just any oil line kit will work. The oil gage will have the correct fitting built in. You will need to check the block fitting. If you try to use a generic oil line kit with ferrules you will ruin the gage fitting and it will leak.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
01-02-2011, 03:05 PM | #10 |
Thanks to everyone for the positive input.
Lewis |
