Old 01-03-2011, 10:05 AM   #1
Kidd-7
Kidd-7's Avatar
Header Gaskets Yea/ Nay????
I've heard no's before, so just wondering Yes No Why????
Kidd-7 is offline   Reply With Quote
Old 01-03-2011, 11:11 AM   #2
hayhauler71
hayhauler71's Avatar
Re: Header Gaskets Yea/ Nay????
Yes so they don't leak
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-03-2011, 11:19 AM   #3
FL71C10
Any suggestions on what kind? Do special bolts make a difference? The summitt website has a bunch of options that get pretty expensive.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 01-03-2011, 11:31 AM   #4
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Buy quality gaskets, not the $9.99 cheapo's. New bolts are a plus. Run them a while, snug them, run tham a while, snug them again. Works for us.
specialtyretail is offline   Reply With Quote
Old 01-03-2011, 11:47 AM   #5
The main thing is to,like said above,keep up on them. Keep 'em tight. Go snug them whenever you think about it. I've had trucks that I could always tell they were getting loose. I got away with tightening for years. Each time I was afraid I was too late,but never was. I suggest spending enough to get the copper crush gaskets they offer these days.
Old 01-03-2011, 12:59 PM   #6
jamesi20
jamesi20's Avatar
I've had good luck with these http://www.summitracing.com/parts/SU...r|1970|CID|350
jamesi20 is offline   Reply With Quote
Old 01-03-2011, 04:58 PM   #7
aggieguy713
aggieguy713's Avatar
Either copper or aluminum...seal the best. Im partial to the aluminum just my .02
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 01-03-2011, 05:39 PM   #8
ldgn63
I've always used stock manifold gaskets with headers. Never had one leak. Somebody tell me what I'm doin wrong...
ldgn63 is offline   Reply With Quote
Old 01-03-2011, 05:59 PM   #9
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Stock manifold gaskets work great.....
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 01-03-2011, 06:55 PM   #10
vectorit
What?
vectorit's Avatar
Back in the day when I had the patience for headers...
I had good luck for the most part using the plain "Mr Gasket" gaskets, but what I did was soak them in water for a while. Then install them with the bolts tightened up, run the engine for a while in the driveway then re tighten them again.
Doing it this way on a shoe string budget worked well for me.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-03-2011, 07:19 PM   #11
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
http://www.totallystainless.com/2010.../catalog35.pdf
Go to page 5 and locj at the Total Loc header bolts - hands down the best header bolts made ANYPLACE!
No screwing around with a bunch of retighting, alan head bolts or tiny ring locks.
These come as 1 piece with captured special lock washers really slick - and they work.
For gaskets I have found percys sealforgood Aluminum work very well
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-03-2011, 09:01 PM   #12
Mike C
Mike C's Avatar
Cast iron manifolds are installed without gaskets. At least when new the heads and manifolds are machined flat.
Headers need gaskets. Get the gaskets that have the wire mesh in the middle. I like the FelPro better than Mr.G, but the Mr.G ones work OK. You can use stock ones if you have 1 1/2" headers and MAYBE 1 5/8". 1 3/4" require small race port gaskets if you want to take full advantage of the big tube. Not much use on a stock head, though.
But get some bolts that have lockwashers. I ran the same set of gaskets for 10 years on my Jimmy. The gaskets lasted longer than the flanges.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
