Old 01-04-2011, 02:58 PM   #1
c10seconds
c10seconds's Avatar
Do i need swaybar brackets with my current susp?
Im wondering if the brackets will make a difference in my from suspension. I ask because I've seen two different size brackets that cpp offers and I've also seen a few dropmember guys bolt the swaybar directly to the frame.
Im using cpp upper/lower lca's, 2"spindles, ss7 bags and the cpp swaybar.
c10seconds is offline   Reply With Quote
Old 01-04-2011, 03:39 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Do i need swaybar brackets with my current susp?
I'd bolt it directly to the frame.
Keith
Convert to disc brakes.
Old 01-04-2011, 05:46 PM   #3
SCOTI
SCOTI's Avatar
Both my 68 Beater & my old 74 had the sway bar bolted directly to the frame because of the drop amount.
With 2-4" front drop, I'd use the 'short' brackets (if you have to get them), or install the bushings on the inside lip of OE brackets (if you already have them). With 5" or more front drop, skip the brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-05-2011, 04:02 PM   #4
tonypaul
tonypaul's Avatar
I ended up getting the shorter brackets from ccp. Im using a sway bar from a '79 5/8 ton truck and guess its different that the stock one. (my truck didnt have a sway bar on it when I got it) If I bolted the sway bar directly to the frame the sway bar would hit the cross piece that goes under the motor. Did all 67-72 come with sway bars? The reason I ask is that I had to remove 1 rivit from each side and drill 1 hole on eack side for the brackets to mount up...
tonypaul is offline   Reply With Quote
Old 01-05-2011, 04:18 PM   #5
scrapmetalart
Junior Member
mine on my 67 from a 87 hit without the brackets on the frame. The short ones would work....
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 01-05-2011, 08:02 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
Bolt it right up to the frame... no brackets needed.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
