Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-06-2011, 11:17 AM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Rollcage pics anyone?
Hey guys, I'm toying with the idea of putting a cage in my '69 C10, but I don't plan to run tubes out the back of the cab to the rear frame rails. I would love to see some pics of what you guys have done and your thoughts about where/how to attach this to the frame. I do have a welder (Hobart Ironman 210) and the tools to cut/notch all the tubing, but I don't know if I should farm this out or try it myself. My primary motivation is really to stiffen things up for cornering, as this will be a 'Pro Touring' type build, but it will see some 1/4 mile action too. The motor and trans is in my sig, and I will be putting out around 600hp- so when I things dialed in, I will be running fast enough to need a cage anyway.
Thanks in advance for the pics, input and advice!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-06-2011, 11:40 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Rollcage pics anyone?
If you are going to install a cage in your truck, I would strongly recommend running at least a pair of rearward bars off of the main hoop. Depending on how fast/quick you end up going, the cage will not certify without those rearward structures. When I worked at Gale Banks, we built a couple of trucks that placed the rearward bars through the window, so there were no holes through the cab structure. The windows were Lexan/polycarbonate, so it was easy to notch or cut holes. This photo is of the S-10/15 that Don Ness built that uses the same concept:
Also, if this is your first roll cage build, I would work with a professional chassis builder, or contract it out.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-06-2011, 05:02 PM   #3
rattleon
rattleon's Avatar
I agree w/vin63, you should run them out the back now. It's going to be easier now rather than later plus it sounds like you already know you'll need them later anyways.
I installed my cage after the fact, as I was building my '70 as a driver and I had already painted the inside of the cab, jambs, firewall etc..and started assembly...then decided to change everything and go do a little racing with it.
Here are some pics of mine. Made it a little tougher because of the finished paint, but I think it will work.
1970 c-10 short/step box morphing into street/strip
1967 RS/SS convertible Camaro
1932 Henry Ford steel 5 window coupe highboy hotrod
1931 full fendered model A sedan AV8 traditional hotrod.
1934 Ford 5 window coupe and a (pile-of-parts)
1929 Model A coupe, plus our "normal" people vehicles.
rattleon is offline   Reply With Quote
Old 01-06-2011, 05:34 PM   #4
team39763
Doesn't Marv have his rear bars tucked out of sight...like below the window? I saw one other truck done something like that, but it was a full tube chassis truck.
Anybody got any pics or details about doing the sidebars where they connect in the front floor?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 01-08-2011, 11:38 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Originally Posted by team39763 View Post
Doesn't Marv have his rear bars tucked out of sight...like below the window? I saw one other truck done something like that, but it was a full tube chassis truck......
Yes I do, BUT,, that's also why I have to slow it down to 11.50 and slower. IT AIN'T NHRA LEGAL. You can see the rear bars going through the bed, into the back brace, instead of the main hoop, in this picture
The ROLL BAR OR A CAGE cage MUST have the rear supports, the they MUST attach within 5" of the top of the main hoop, THE MAIN HOOP must be NO MORE THAN 6" above the drivers helmet.
You can put a secondary bar across the uprights 5" below the main hoop to attach to, OR you can bend the rear supports to come inside the cab (through the window) and then turn up the 6" to meet the main hoop.
Option is a funny car cage like Kevin's, I think you can get away without the rearward supports with that type of structure. But even then you will typically see the rear supports through the cab to make the structure rigid. At that level aesthetics are less important than safety!
Of all the welders, grinders, angle finders... the most important tool in building a cage or a bar is the RULE BOOK. Seriously,, have the rule book in your left hand when your cutting tubing stock with the right. That NHRA rule book is a slippery slope.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-06-2011, 07:57 PM   #6
Irish's_79_Step
Irish's_79_Step's Avatar
sorry wrong button.
Irish's_79_Step is offline   Reply With Quote
Old 01-06-2011, 11:00 PM   #7
djracer
djracer's Avatar
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-07-2011, 11:26 AM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
Thanks for the closeup and detailed pics. That's the kind of stuff I needed to see,like where/how to attach it to the frame.
Ratteon - I'm kind of in the same situation as you, I got into my build and realized I needed to make some changes. I haven't paintedmy cab yet, but I have painted the frame already, which now I'm glad I painted instead of powdercoated, so I can fix it after welding the cage it.
As for the rearward bars, I know they do offer a lot more rigidity and that's what I need, but man I really wanted kind of a subdued look to my truck (eventhough I have 335 rear tires out back!), and those bars poking out the back glass blow that out of the water. Maybe I can kind of hide them like team39763 said, but I don't know how that would affect their legality at the drag strip.
Adam
Old 01-08-2011, 04:55 AM   #9
Irish's_79_Step
as far as i know for the cage to be legal the rear bars have to be at the highest point of the main loop. and the main loop has to be all one piece.
Old 01-09-2011, 10:44 AM   #10
team39763
Hey Marv, will yours pass for just test'n'tune sessions?
Old 01-09-2011, 12:02 PM   #11
Marv D
Marv D's Avatar
Absolutely not for anything quicker than 11.50 . It's a issue I fought with NHRA and was able to win over the techs here in Az with help from Division 7 senior tech. The rule states all equipment must pass tech. In short if you 'HAVE' a piece of equipment, it must pass tech, be current, etc.
An example we put a set of expired 3" belts in my son's 14 second camaro. Tech would not pass him because of the expired belts. Now mind you a well installed, but expired 3" harness (and 3 years old) is a heck of a lot better and safer than the stock 1985 GM belts being 20 years old. The rule just did not make sence. But the techs stance was "ALL" equipment must pass inspection. And he was right! They didn't say 'IF IT IS REQUIRED" it just says it must pass. An expired piece can't pass because it's expired so,, FAIL. Same issue with this bar. If I run 11.50 and slower the bar isn't required. I called the senior tech for Division 7 in Glendoria and there is some loophole that 'optional equipment' not intended for competition does not have to be removed as long as all 'reguired' equipment is in place and current for the ET ran. Mike pointed out the roll bar on the Cobra kit cars, the Miada and a bunch of other 2-seaters that had a decroative roll bar. This was back before NHRA moved the roll bar rul;e from 11.99 to 11.49 noting that most of these cars would barely break 14's let alone 11's.
So I guess the answer to what your asking is not a blanket NO,, just NO to anything quicker than 11.50. Slower and it's 'decroative'
Old 01-09-2011, 09:08 PM   #12
regan wilson
regan wilson's Avatar
See below
regan wilson is offline   Reply With Quote
Old 01-09-2011, 09:08 PM   #13
regan wilson
I have pondered the idea of the funny car cage deal ! I gettin too old to bend that much when I get in and out . My opinion is the rear strut bars add alot of structural integrity to the truck . I can put a jack under one framerail and jack the truck up and the other frame rail doesnt sag hardly any at all. You can look any of my wheels up pics and my truck doesnt twist .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
Old 01-09-2011, 09:40 PM   #14
regan wilson
Old 01-09-2011, 09:41 PM   #15
regan wilson
Old 01-09-2011, 09:43 PM   #16
regan wilson
Old 01-11-2011, 12:03 AM   #17
djracer
djracer's Avatar
Nice looking setup.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-13-2011, 11:12 AM   #18
D13
D13's Avatar
You can't cut a hole in that glass. Lexan.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-14-2011, 10:23 AM   #19
team39763
Check the local glass/window store for Lexan, you'll probably get the best deal on it. I used to order mine through Ebay and my local glass/window shop beat the Ebay price by 50%.
Old 01-21-2011, 11:58 PM   #20
noonzor
anyguys got more pics on how they are connecting the main hoop to the frame?
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 01-22-2011, 07:54 AM   #21
regan wilson
Look at the diagonal bar that goes behind the seat in LJ534's pics . Thats the one you need to go to the frame with . The four corners of the cage just need stitch welded and bolted plates on the floor of the cab .(if you still have the steel floor) and of coarse you need solid cab mounts .
Old 01-22-2011, 11:39 AM   #22
Marv D
Marv D's Avatar
Regan,, I surely wouldn't argue with someone of your calibure, and you see the toughest tech in NHRA so I'm 'asking' here, not arguing. The way I read the rules was that IF the vehcle has a 'frame' the main hoop and front down bars must be attached to the frame, not the floor (with plates) via outriggers of some sort. I did much the same as rattelon (and is probably the only thing I thought was 'legal' at all about my cage!!)
(darnit, can't link the picture from above)
Are you saying the main hoop and front down bars of the cage don't have to attach to the 'frame'? That would be Soooo much easier!
Old 01-22-2011, 08:40 PM   #23
LJ534Rat
Couple more pictures of main hoop to outrigger on frame and others. I still have the measurements for the main hoop that was sent to S&W that they used to bend the main hoop.All the other bars were done custom locally .Cage has not been certified but should meet requirements.
'72 SWB 534" 10.5:1 W/GMPP 290CC Ovals,
Wilson Pro flow 2 stage,Transking man. rev T400 W/Trans brake,Moser Dana 60 w/4.30,,Indigo blue W/ghost flames,shaved,smoothed and low,9.40's @ 138
LJ534Rat is offline   Reply With Quote
Old 01-23-2011, 12:00 PM   #24
regan wilson
Yes thats what I'm saying . When we built my cage I consulted with longtime Div 4 tech man Harold Hayes through the whole process . I even had him check it before we painted it . When we were done it certified to 7.50 now it is an 8.50 becuase of rule changes (a funny car cage would be needed). I'm not nocking the way any one has done thiers . I think if you didnt have the steel floor you would for sure have to have the outriggers . Since mine has the stock steel floor and the cab is solid mounted to the frame I guess it met thier requirements . The only bars I have that go to the frame are the front and rear strut bars and the down bars behind the seat . I have never had even one problem about the cage at any track from Texas to Geargia to Chicago and all the other places in between.
Old 01-24-2011, 11:09 AM   #25
Marv D
Marv D's Avatar
That's why it's so valuable having guys like you around here I know well the NHRA techs at the national events are HELL on every little detail and you are PROOF we don't 'have to have' the out-riggers off the frame for the main hoop. I read the book just as so many others have I guess, and built 2"x3" frame extensions to support the main hoop and front cage bars. If I had realized I could have welded them to the floor on a plate........ wow what a LOT of work I caused myself.
Oh well,,, when I make the cage 'legal' it's going to be a heck of a lot easier now!!!!
Only question is if having stock rubber cab mounts would make any difference in tech opinion there. You say your cab is solid mounted I assume with a solid aluminum body bushing replacing the stock rubber mount?
ummm now on second thought....... I guess now unfortunately I have compromised the stock steel floor board by cutting over sized holes for the uprights to go through. Before I could weld a cage / plate to it I probably would have to replace the piece of floor back to 'stock'. Tech can be so darn picky about things like that. Simply replacing the area with a patch of like 12g sheet stitched in,,,,, bet they will balk unless it's an OEM 'appearing' piece of floor. In my case I think the damage is done and the outriggers sure don't hurt from a strength issue.
But you guys who have yet to hack the floor to put a cage in,, should TAKE NOTE OF THIS THREAD
rollcage
